GasOil....Arrrgh!
Old Apr 16, 2009 | 09:14 PM
GasOil....Arrrgh!
I helped a buddy change the tires on his Goldwing today. Anyone ever done that before? Gotta take the whole back end of the bike off!
So after wrenching for hours we were going to go for a short ride. I wanted to ride the VTR since I hadn't had her out yet this year. I started her up and she was only running on one cylinder. Hmmm, didn't do this a couple weeks ago when I started it for the first time this spring. Oh well, gotta take the 1000RR. Darn.
Get back from the ride and there's a huge puddle of gas on the garage floor under the bike. Holy crap! So I knock the carbs with a screwdriver handle a couple of times and try to start the bike....click, click. WTF?!?! Hydro lock!
Turns out a float valve had stuck open, filled the airbox which then ran over to the other carb and filled that cylinder too! I Mity-vac'd about 360ml of gas from the rear cylinder and another 50ml from the front, and probably 500 ml from the airbox and carb throats. What a PITA!
So I pull the carbs, get everything cleaned up and the bike starts up pretty easily. I shut her down after about 30 seconds and pull the oil cap. GasOil! 4 quarts of Mobil 1 shot to ****!
I went to Walmart to get more oil smelling like a friggin refinery!
T'was in interesting day.
Old Apr 16, 2009 | 09:18 PM
Byrdman's Avatar
Super Byrd
That happened with my four wheeler, clean the carb and it runs great now
Old Apr 16, 2009 | 09:26 PM
RK1's Avatar
RK1
Smart of you to check the oil. Four quarts of Mobil1 are probably cheaper than the result of running on the equivalent of 4w12.
Old Apr 16, 2009 | 09:29 PM
j shizzy wizzy's Avatar
mildly retarded
that sux!
Old Apr 16, 2009 | 09:47 PM
Truckinduc's Avatar
man, I know what that feels like. Happen to my ducati more than once, usually when I was away from home.
Turns out my fuel pump was full of, of all things, Grass.
Old Apr 16, 2009 | 09:59 PM
yruyur's Avatar
Old Apr 17, 2009 | 03:23 AM
FTMS's Avatar
Greg- You diddn't like changeing the tires on an Goldwing. The new 1800 are a lot easier with the SS swingarm. Older GW suck!! You really don't want to do a Valkery either.
That sucks about the float valve.
Old Apr 17, 2009 | 03:49 AM
chickenstrip's Avatar
chickenstrip
Good problem solving on your part, but yeah, what a PITA! Good thing you had a the Mighty Vac .... it wouldn't have occurred to me to use it for that - show's you what I know about 'em.
So you're saying don't buy a Goldwing??
Old Apr 17, 2009 | 03:55 AM
gboezio's Avatar
That could have created a pretty nasty fire, still be careful with that thing, hydro locking plays hell on con rods, in fact it's better to have a full cylinder than 50 to 100 ml of liquid.
Before the Hawk I had a ZX-9, bent a rod from an hydro lock, did 200 kms and lost the rod at 200 km/h, huge fireball, was fun but expensive.
The VTR rods are stouter, if you want to check them, you can use the tail part of a caliper trough the plugs holes (if it fits), and sweep the piston BTDC to ATCD, holding the caliper while the piston push the caliper rod, you should get the same measurements on both cyls, on a bent rod cyl the piston sits lower.
Old Apr 17, 2009 | 05:57 AM
L8RGYZ's Avatar
Cool that you figured it out.
So did you have to replace any parts? Is the float likely to stick again?
Old Apr 17, 2009 | 06:14 AM
BeerHunter's Avatar
Slacker
Did you happen to check the function of the vacuum petcock? It's design is for safety and as such should prevent such a large fuel leak from occurring.
Old Apr 17, 2009 | 06:21 AM
dakmatik's Avatar
dakmatik is on a distinguished road
I'm guessing that the vtr carbs don't have overflow drains like they should. At least you got out of it easily, could have been a lot worse had you not checked you oil.
Old Apr 17, 2009 | 06:48 AM
happytrack44's Avatar
WERA #44
The petcock can malfunction and stay open. If your float seats properly, gas will pee out the carb overflows (those black tubes that are tied together between the carbs) and not into the engine.
Petcock rebuild if it happens. No smoking around the Hawk.
Old Apr 17, 2009 | 07:34 AM
mildly retarded
Heeeeey... did you say you used regular old Mobil 1??? I thought these bikes needed special oil for the clutch and what not????
Old Apr 17, 2009 | 10:11 AM
swordfish's Avatar
kidding I hope? we are flirting with an oil preference discussion. avert! avert! mobil 1 20w-50 ftw
Old Apr 17, 2009 | 10:16 AM
mildly retarded
Nevermind, I looked it up. I was just thinking about my Jeep at the time. didn't know wal-mart sold moto oil either.
Old Apr 17, 2009 | 10:59 AM
Good thing you didn't get a carb fart during that 30 seconds it was running. I know there must be a flame arrestor in the PCV system, but that could have been one big bang.
Early '70s Chryslers used the crankcase to store fuel vapors for the EVAP, instead of a canister. I know 2 guys who witnessed the valve covers blowing off a 318 V8.
And that was on 2 different cars.
Old Apr 17, 2009 | 11:50 AM
chickenstrip
Can someone explain 'hydrolock?'
Old Apr 17, 2009 | 12:01 PM
zmaniv's Avatar
Cylinder filled with a fluid with no way for the fluid to escape (Valves shut)
The piston cannot move upward because of all the fluid in the way.
Old Apr 17, 2009 | 12:03 PM
Stevebis1's Avatar
Fluids (Hydro) don't compress. Fill a cylinder full of gas and the piston won't move (lock). Fill it with just a little bit of fluid and the piston moves right up to the point it stops . Thus bent rods.
Not uncommon on civics, tsx, and other jap cars with aftermarket cold air intakes. Drive through a deep puddle, suck up water and your screwed
Old Apr 17, 2009 | 01:38 PM
CentralCoaster's Avatar
The good news is your crankcase is very clean now.
Old Apr 17, 2009 | 02:23 PM
Circuit_Burner's Avatar
guru of things sparky
Goldwing rear tires are the worst to change... especially on 1970's or 1980's models.That and some harleys with spoke wheels.
(shudders)
But if you think thats bad ...
I have a goldwing stator we are rebuilding for a guy that just paid $400 bucks to have the engine removed so he could get the stator off the bike for replacement.
Removal of the engine is standard procedure for anything involving the stator or flywheel on goldwings.
typically a $1200 job. And ZERO fun involved.
Old Apr 17, 2009 | 07:25 PM
I don't think the rod is bent. I started her up last night after the oil change and she runs great. There was one tiny chunk of black **** that fell into the pan I was draining the gas into. I'm pretty sure that was it, just don't know how it got in there.
As for the petcock, yeah mine has been sticking for years. I guess I've been lucky up until now. I took it apart about 2 years ago, cleaned and lubed it with silicone spray. Guess it didn't work.
Old Apr 17, 2009 | 08:29 PM
Randman's Avatar
Moderate-whore
What? that don't sound so hard, and stuff...LMAO...dude, did ya throw something? Makes me feel better to throw something...
Old Apr 17, 2009 | 09:44 PM
Rods don't bend unless it got almost a full stroke before hitting the hydrostatic lock.
I had a piston and bent rod out of a Camaro in my classroom for the last 20+ years. Worst is sudden head gasket failure with the engine running...piston goes down on intake pulling in coolant, then comes up on compression and that's all she wrote.
I don't think the starter motor on a car or bike has enough torque to bend a rod.
Old Apr 18, 2009 | 12:56 AM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
Ditto...
Old Apr 18, 2009 | 12:58 AM
loserbaby's Avatar
jet wrench
I goto Wal Mart smelling like a brewery!
Old Apr 19, 2009 | 12:36 AM
IAGeezer's Avatar
IAGeezer is on a distinguished road
Had the same thing happen back in November. Started to run badly, got home, parked it for the night. Next morning, Big puddle of gas underneath the bike, leaking from Y-pipe.
Rolled her out into the alley, flipped the kill switch off, hit the ignition and just blew all the gas out the pipes! Quite the show, but stunk the place up pretty bad. Checked the oil, it was half gas, so I changed it out, and left for Iraq again...
My pal Phil has redone the carbs, and is waiting for a new petcock diaphragm to show up, so he can test ride her. Oh yeah, he installed my Penske shock too! Hope it's done when I get home next month.
Cheers!
Old Apr 19, 2009 | 11:53 PM
I'd like to pull my engine and see out of my junker. Hydrolocked a 302 V8 on seafoam while starting and the engine made only 55psi on one cylinder after that. I've seen a few that buckled but stayed intact and didn't grenade the motor.
Plus those bike internals are smaller in comparison.
Old Apr 20, 2009 | 04:32 AM
gboezio's Avatar
It's related to the amount of fluid trapped in the cylinder and crank speed, at TDC the starter have an infinite leverage, at 90°BTDC, the starter has minimal leverage, the combustion chambers have around 50 cc, dump 60 ml of fluid in an intake throat, you will bend a rod, dump 250 cc, not so likely.
Take it as : piston displacement/crank degrees = starter leverage.
I had trouble with # 2cyl carb, hydrolocked and threw #2 rod trough the crankcase two week later, the engine had a weird vibration at specific RPM's
I still have that banged up piston/rod somewhere.
I don't want to be alarmist, the odds are probably more that it's ok, but I'm calling a measurement since that locking the rear wheel is a really bad experience and if it happens in a curve, oh ****, a quick clutch grab saved the day, even the week
The one thing I remember, when I hydrolocked the bike, is a loud heavy metalic "klinggg", beeing young and stupid I took the bike to the redline several times and it was ok, until a long medium speed run, hot pots formed.
But hey it was a Kawasaki
