Fuel gauge works off and on
Old Jun 21, 2012 | 12:00 PM
brucebarker's Avatar
brucebarker is on a distinguished road
Hey guys new owner of an '02 hawk here. I'm having problems with my fuel gauge showing full when its not, then shows a 3/4 tank then back to full. any suggestions? Thanks for any and all help.
Old Jun 21, 2012 | 12:11 PM
GTS's Avatar
GTS
Seasoned tech
Welcome to the forum and to being the proud owner of a SH!
Sounds like either a loose connection or a chafed wire to ground. I don't recall on these ones if it's higher resistance for higher level or the other way around. Check all your connections such as the one front the bank to the main wire harness. Also check to make sure the wires from the tank to that connection are good. If these are all good it could be a bad sending unit.
Old Jun 21, 2012 | 12:58 PM
aja's Avatar
aja
4-10 empty, 81-91 full. It could be a failing sending unit of the suggestions gts gave don't help.
Old Jun 21, 2012 | 02:10 PM
comedo's Avatar
I'll gain a bar on the fuel gauge on my '01 VTR going from a level road to an ascending one and I'll lose a bar on descents. I try not to take the gauge too seriously.
Old Jun 21, 2012 | 09:23 PM
The connection for the gauge (one of them) is under the front of the seat in that bundle of connections. I could be corroded or loose.
You can also actully reach in the tank and move the float up & down its full range and see if it reads true but there is some lag time between moving it an seeing the result.
Old Jun 22, 2012 | 07:34 PM
thanks for all of the tips
May 12, 2012 08:52 AM
8541Hawk
Oct 2, 2010 01:36 PM
Mike996
Nov 18, 2009 03:04 PM
tudor
Jun 24, 2008 06:56 AM
BIG DAVE 03
May 17, 2007 03:41 AM
