Front sprocket rubber seal? tossit or save it?
Old Nov 20, 2007 | 05:59 AM
flngscout's Avatar
2005 hawk
flngscout is on a distinguished road
I recently put a 15t sprocket on my SH. It turned out to be more of a project than I had bargained for, but once I got the bolt that I broke extracted it wasnt so bad. Anyhow, my question is this. The OEM sprocket had a rubber gromet sort of thing around that actually is part of the sprocket. Should I cut it and try to put it on the new sprocket or should I just install the new 15t as is?
Old Nov 20, 2007 | 06:44 AM
superbling's Avatar
Install as is. It's too dampen noise/vibration and isn't removable. AFAIK, only the stock units are like that.
Old Nov 20, 2007 | 01:08 PM
flngscout's Avatar
2005 hawk
cool thanx. I just got done installing it, ended up keeping the same chain even though a new one came with the kit. I thought the 2 up in the rear dropped some ballz in it but that def did the trick. Thanx for the input
Old Nov 20, 2007 | 01:53 PM
If you've got more than 10,000 miles on the OEM chain, replace it with the new one you have anyway!
maniac2313
Jun 28, 2011 04:53 AM
Gerrit
Feb 12, 2008 10:40 AM
reaper
Sep 12, 2007 03:14 PM
Darkone22
May 19, 2007 04:02 PM
Loco
Jan 25, 2006 05:56 PM
