Front brake doesn't trigger brake light, HELP
Old Jan 30, 2012 | 08:20 PM
VThokie412's Avatar
VThokie412 is on a distinguished road
Ok, so I just bought my SH, and today I was playing around with it and realized the brake light doesnt light when the front brake lever is pulled in. The rear brake pedal works though, however it must be pressed hard to get the light to work. What should I do? How do I test the front brake? Is it stuck on (if that was the case though then wouldnt the rear seem to not work at all?) Where is the front brake switch?
Old Jan 30, 2012 | 08:27 PM
saige's Avatar
the boss
the brake switch is on the bottom of the mc,or underneath to the left of the lever.
if you slowly pull in the lever,you should hear a clicking,thats the switch,make sure its plugged in or change the wires around.
for the rear,you can adjust the switch,its on the mc of the rear brake lever with a spring to it and a little nut.thats where you adjust it.
Old Jan 30, 2012 | 08:28 PM
The switch is located right where the lever attaches to the MC I believe. There are two small plugs that attach to it... make sure those are clean and attached. Then go from there.
The rear brake switch is a long cylinder thing with a large thumb twist screw on it. This can be adjusted for sensitivity...so you can fix your rear brake to trigger with less travel as well
Old Jan 31, 2012 | 09:51 AM
VThokie412's Avatar
Rear works, the front is the issue... How do I tes tthe switch? It is plugged in and I hear the click so... bad switch? I have a multimeter, how do i test?
Old Jan 31, 2012 | 10:56 AM
Wicky's Avatar
5 minutes to swap out for a new one - they don't cost much. (part no. 1)
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>FRONT BRAKE MASTER CYLINDER 98-04
Old Jan 31, 2012 | 11:36 AM
scooter72's Avatar
scooter72 is on a distinguished road
To test the switch, unplug the wires to the switch, put your multimeter on low ohms scale and go across the switch terminals and pull the lever. It should change from infinite resistance to almost zero resistance while pulling the lever. If you want to test the wiring to the light, you can just jumper across the wires while they are disconnected, and with the key on, the brake light should come on when jumpered.
Old Jan 31, 2012 | 12:27 PM
jay956's Avatar
Are you in VA? (judging by you screen name) Close to Richmond?
Old Jan 31, 2012 | 12:36 PM
VThokie412's Avatar
I graduated from VT, so I was down that way for a while. The 412 was my area code from my hometown, Pittsburgh, PA. I just moved to Alabama for work though.
Old Jan 31, 2012 | 02:00 PM
jay956's Avatar
Gotcha, was gonna say you can stop by here if you need help.
Old Feb 1, 2012 | 10:28 AM
VThokie412's Avatar
ok so tested the switch, and it says it has continuity, so... where should I look next? I was going to try and jump from the switch to the light to test and see if one of the wires is bad. If thats the case what are my options?
Old Feb 1, 2012 | 10:48 AM
The easier way would be just to connect the two wires attached to the switch... the light should go on when there is a continuous circuit. If the light goes on when they're connected, then wires aren't bad.
jefejrs
May 15, 2015 01:10 AM
aka Yamadog
Feb 22, 2009 04:38 AM
Plague325
Feb 26, 2008 10:12 PM
SD996
Jun 15, 2007 11:06 AM
V-Raptor
Dec 1, 2006 06:35 PM
