Front Axle Collar Dimension CBR 1000 RR
Old Nov 13, 2012 | 02:38 PM
Mike Heffernan's Avatar
Mike Heffernan is on a distinguished road
Do any of you front front end/wheel swap gurus know what is the width of the front wheel distance tube (or collar) on the CBR 1000 RR? I know it's 25mm I.D., what I'm asking for is the distance it maintains between the inside faces of the bearings. Thanks in advance for any help
Old Nov 14, 2012 | 04:23 AM
98VTRrider's Avatar
I just pulled my CBR1000RR front end off. If I get time I can find those measurements for you. If I don't reply by a few days just send me a PM to remind me.
For "distance it maintains between the inside faces of the bearing", you mean as if the bearings were removed, the distance from the inside bearing land to the other side bearing land.
So if I measure from outside of each bearings would that help? could you subtract the thickness of both OEM bearings to get the measurement you want? I don't want to pull my bearings to get the measurement, if that's the measurement you need.
maniac2313
Jul 5, 2012 05:44 AM
salmanilla2000
Mar 29, 2011 09:25 AM
bigbob65
May 25, 2007 11:49 AM
ali_squidz
Apr 9, 2007 05:46 PM
meangreen79
Feb 13, 2007 05:53 PM
