Fine Tuning Carb Q.
First of all let me thank you guys for your knowledge. I have learned a lot on here. That's for sure!
I just did the carb set up 8541Hawk wrote up (although I had some issues because my diaphragms weren't sealed correctly...woops). The midrange power is now awesome. I am hoping that someone can chime in and help me get these suckers tuned a little better. First of all, my idle is pretty rough, and it even died on me a couple of times at stoplights. It's not a steady idle either. Second, I seem to stumble around 6k while under full throttle. Is it possible that I need bigger mains? Or would more shims help?
I know that it's now a process of trying one thing and seeing how it work, but where do you guys think that I should start at?
Once that is done, then and ONLY then do you start with finetuning the carb setup... Preferably also check or re-set your TPS to spec, but not entirely neccesary...
mduck
Oct 8, 2013 09:14 AM
fz911
Aug 29, 2010 10:42 AM
