finally a real R/R swap
Old May 19, 2010 | 01:19 PM
  #31
FYI, the forum doesn't understand HTML use [ ] bb code
Old May 19, 2010 | 04:10 PM
  #32
Erik S.'s Avatar
Conflicting information. If you talk to others, the ground strap is unnecessary, since it is going straight to the battery, the green wire.
Doom, there is so much info on this board about swaps........use the search, you'll even find out that there are some that don't require different triple trees.
I knew this was out there, but if you'd searched, you'd have found it. You don't even have to find the parts, this is one stop shopping. https://www.superhawkforum.com/forum...ad.php?t=22355
Old May 19, 2010 | 05:31 PM
  #33
Correct... The green wire goes directly to the battery... But you still need the groundstrap...
It works without it, but you reduce life of the R/R ... Research multiple point grounding and electrical interference/resonance...
mopar_man
Sep 2, 2012 06:56 AM
smokinjoe73
Jun 28, 2012 12:02 AM
khanawalt
Apr 2, 2007 08:22 AM
Radiaoktiv
Feb 2, 2007 06:41 PM
Sgt Rock
Mar 10, 2006 06:10 PM
