F4 shock
Just got a F4 shock made to fit the hawk. Only problem is the compression adjuster only has about 1/4 turn of movement. Any ideas what the problem could be? Rebound seems fine with 2.5 turns.
Originally Posted by jay956
(Post 324116)
(Post 324128)
Likely damaged by being turned past the stop.. Very common,, They show failure in two mods.. Like yours, and free turning with no stop at all.
Took it to a shop down here, theyre gonna look at it.
Does anyone the specs for a superhawk shock? Dimensions, length, mounts... Talked to Thermosman and he might be able to make one for me. Just need some numbers and I dont have easy access to my bike right now.
(Post 324117)
Check with Jamie Daugherty. He rebuilds those for Superhawks.
Re length: In this thread (still best measure your own shock or give it to them as a pattern )
https://www.superhawkforum.com/forum...t-shock-18087/ |
Well one good thing has come from this. I'll have a brand new Ohlins coming my way in a couple weeks.
Turns out the emulator was installed backwards. Guy at the shop charged it to 140psi but said he wasnt positive if that was correct. Does anyone know the correct pressure?
(Post 324290)
Thanks. Do you know how being under charged would affect the performance? Don't have time to get it topped up before I leave for the track.
Aeration, some dampening loss perhaps... I have the technical ability to build forks shocks to OEM, others specs, I do not claim to be a suspension wiz.
Im a cook, I can follow a recipie, I am not a chief. |
