engine clacking
engine clacking
I recently purchased an 98 with 17500 miles on it. The bike came with a well documented maintenance record i.e. oil changes,valve check. The bike was due for an oil change so I went from Honda 10-40 to Mobil 15-50
synthetic. The bike has developed a clacking sound at 1500 rpms only with or with out the clutch in. In every other range the bike sounds perfect. The acceleration is not affected in anyway just this clacking accelerating/decelerating or idling at 1500 rpms. Any input would be greatly appreciated.Thanks
Dante1
Dante1
The carb slides have a tendency to open and close from the pulsing of the big cylinders, this could be verified by removing the air filter and run the engine while you check down the carb throats.
You can take off the tank, there's enough fuel in the carbs to make a test run.
Slide sound is almost normal operation, nothing really wrong, I can't really hear them on my bike, but a lot of VTR owners report to hear them loud, try a search on this forum, you should find many threads about this
It's the RPM window that points toward the slides, if the cam chain became slack, it would happens on decel. But check it out ASAP to make sure it's not CCT related, all you need is a 8mm socket and a Phillips screwdriver, you can just lift the front of the tank without removing it.
mootsmadness
Sep 11, 2011 10:51 AM
REDVTR1000
Apr 25, 2008 12:14 PM
