electronics geniuses - home-made speedo corrector?
Old Dec 10, 2009 | 11:14 AM
avramd's Avatar
avramd is on a distinguished road
Hello,
I'm fiddling with the idea of changing my gearing, but I don't want to cough up $115 for the speedo healer. Too many features, a whole computer in there - it just seems like overkill when all we need is to generate an output pulse whose frequency is determined by a variable input pulse.
This sounds to me like the kind of thing that someone with the right know-how could wire up with some diddly little $5 chip and the right combination of resistors capacitors and diodes - and then we could all use it.
Has anyone looked into this?
-Avram
Old Dec 10, 2009 | 12:24 PM
trinc's Avatar
there are a number of ways to go about it but a PIC would be the easiest. and yes it's very cheap... and not that hard to program BUT - you'll need to make a PC board & seal it in a box, make a harness with the proper connectors to be plug & play....
buying just a couple parts at a time w/ shipping i'd bet you'll spend $50.
then you need a programmer ( yes, i have a few ). you can get a compiler
free after you debug the program.
by the time your done with it you might as well just spend the $100 to buy one ( unless you have a lot of free time ).
old school... you could program ( by the external DIP switches ) a simple counter but it'll have a lag in it. there are ways to reduce that but would require more space.... so like i stated a PIC would be the way to go.
imo
tim
Here is a kit to do it yourself:
http://www.jaycar.com/productView.as...=&SUBCATID=347
Here is programming that one: http://www.600rr.net/vb/showthread.php?p=1526467
To actually design one yourself that could be programmed for different sprockets etc would be a pain..
Really even with that "cheap" one up there, with the hassle and time etc, just buy a speedohealer or yellowbox for $115 and be done with it. Cheaper in the long run.
Old Dec 11, 2009 | 12:26 PM
divingindaytona's Avatar
Remember stock is BAD!
Or you could just use a bicycle computer, set the rim size, and be done with it.
Old Dec 12, 2009 | 09:12 PM
toy4xchris's Avatar
toy4xchris is on a distinguished road
You can just be lazy like me and well if cars are passing you speed up and if your passing them your good lol. I never really look at my speedo anyways.
Old Dec 14, 2009 | 04:06 AM
Erik S.'s Avatar
+1
Old Mar 7, 2010 | 07:35 PM
avramd's Avatar
FWIW, I do like to keep track of my fuel economy. I mean yeah, the hawk is a guzzler by bike standards, but I still like to know if its guzzling more than it should be.
Also, if you're passing them, that could mean a lot of different things. For example, if they are going 65, it doesn't mean much. If they are going 85, then you could get into a fair bit of trouble.
Old Mar 8, 2010 | 05:15 AM
NCDave's Avatar
Just get an inexpensive GPS and mount it someplace. it shows accurate speed and keeps track of miles too.
Old Mar 8, 2010 | 07:56 AM
peterpanic's Avatar
pragmatic anarchist
+1.....but I actually do more like toy4xchris. I just glance at the speedo whenever I need a surprise.
mikstr
Apr 8, 2009 04:25 AM
bikerpiker
Mar 24, 2009 01:40 AM
bikerpiker
Mar 7, 2009 02:56 AM
chuck_b
Aug 22, 2008 02:35 PM
mikstr
Feb 3, 2007 05:08 PM
