electrical problem
Old Oct 17, 2008 | 06:47 PM
horseshoe's Avatar
horseshoe is on a distinguished road
electrical problem
never posted a thread before. old guy new at this. problem is my 98 superhawk is blowing the main fuse every time i replace it, appairently it has a short. any place or circut i should start?
Old Oct 18, 2008 | 03:09 AM
dakmatik's Avatar
dakmatik is on a distinguished road
I believe the service manual tell you how to check through everything. It would be a major PITA, but I'd start at one end of the bike and work my way across, checking everything as I went.
Old Oct 18, 2008 | 04:02 AM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
Need more info:
What year bike?
Does the fuse blow upon replacement without turning the key on?
Old Oct 18, 2008 | 08:59 AM
RickB's Avatar
For starters try unplugging the R/R (regulator/rectifier) and then try the stator connector which is also part of the charging system - these seem to be the more common electrical problems... After that it could be a wire shorting out somewhere from worn insulation which can take a bit of tme to find.
Old Oct 19, 2008 | 01:26 PM
armyguy8381's Avatar
armyguy8381 is on a distinguished road
R/R..... Mine Kept blowing.. Need to Change that baby fast.. Should fix all your problems
rahjer
Oct 29, 2008 07:24 PM
mcbrien
Nov 12, 2007 10:26 PM
elijahawk
Oct 13, 2007 03:56 PM
redman
Jul 24, 2007 10:16 PM
jagermonster
Jun 14, 2007 06:35 PM
