electrical problem
electrical problem
never posted a thread before. old guy new at this. problem is my 98 superhawk is blowing the main fuse every time i replace it, appairently it has a short. any place or circut i should start?
Need more info:
What year bike?
Does the fuse blow upon replacement without turning the key on?
For starters try unplugging the R/R (regulator/rectifier) and then try the stator connector which is also part of the charging system - these seem to be the more common electrical problems... After that it could be a wire shorting out somewhere from worn insulation which can take a bit of tme to find.
