electrical issue ??
Old Aug 11, 2010 | 05:44 PM
Seattle_SuperHawk's Avatar
WWTDD
electrical issue ??
has anybody had an issue with the SH stalling very briefly... then loosing the trip meter and clock, both resetting to Zero. bike isn't running hot, starts just fine, no other issues. this happens maybe twice a month. any ideas or threads...i looked but didn't find
Old Aug 11, 2010 | 06:16 PM
There is a major harness junction under the seat just aft of the tank. You have to remove the seat to expose it. I see you are in the PacWest where there's lots of moisture. Check this bundle carefully as mine fried and caused all sorts of problems. Mine was all corrosion of the connectors. I removed them, soldered the wires together and coated with shrink and it was all good. Also check the sidestand switch as this can cause problems in wet weather as well.
Old Aug 11, 2010 | 06:36 PM
autoteach's Avatar
check all battery cable connections (at the batt. and at the engine/solenoid). Go from there with checking the battery (you can take it in to an autozone). From there check harness connections.
kraher
Jun 24, 2010 04:33 PM
98ILVTR
Mar 15, 2010 06:19 PM
superman_006
Mar 1, 2010 07:52 AM
Blurpy
Aug 20, 2004 06:52 PM
Blurpy
Aug 19, 2004 08:35 PM
