Electrical Gremlins
Old Mar 17, 2010 | 10:39 PM
Skrapper68's Avatar
Skrapper68 is on a distinguished road
Electrical Gremlins
It all started when my left blinker worked sparadically, I found a black wire had come unhooked so I plugged it back in and the blinker worked for a couple days. Then the blinker light stayed on all the time not blinking it was just lit up. Then last night riding home the speedo, tach, and mileage display started going crazy. Any suggestions? I'm not super advanced mechanically but not completely inept either.
Old Mar 18, 2010 | 12:49 AM
residentg's Avatar
I am not expert either, I know that on the VFRs (Interceptors), that if the battery is weak, the intruments act wierd sometimes. How is your battery? Are your symptons at low engine rpms - that is when a battery is supplimenting current. Do the other blinkers work ok? If you re-dissconnect that black wire, will the instruments then work properly?
Old Mar 18, 2010 | 04:58 AM
Bandit00085's Avatar
Bandit00085 is on a distinguished road
check all of you connectors for corrosion. including your battery cables. might also be bad battery of charging issue like residentg said.
Old Mar 18, 2010 | 12:06 PM
PUSHrod's Avatar
If you are checking connectors, while you have 'em open clean the oxidation off and use di-electric grease when you put them back together. Saves failures down the road.
Wonky instruments are a symptom of a weak battery and/or charging system.
Old Mar 18, 2010 | 07:53 PM
Skrapper68's Avatar
Thanks everyone. Tomorrow is my day off so it looks like I know how I will be spending it.
Old Mar 19, 2010 | 10:07 AM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
Check your R/R. If you do a search you might come across a couple references to it.
bugsy27
Jan 12, 2014 01:16 AM
wildride21
Feb 16, 2011 04:41 PM
jonesey
Aug 9, 2009 01:29 AM
smokinjoe73
Aug 6, 2008 04:21 PM
elijahawk
Oct 13, 2007 03:56 PM
