Difference with exhaust systems from bike to bike...
Old Jun 25, 2009 | 07:14 PM
j shizzy wizzy's Avatar
mildly retarded
So what is the big deal between bike exhausts? Can I use any exhaust I want within comparable size limits? Like could i use 2 R1 pipes for my superhawk ,if I were to rejet? I want to know just how many different pipes I can actually use if i am willing to have my own midpipes made...
What does everyone think/know about this?
Old Jun 25, 2009 | 08:19 PM
I think most make a standard can, then form the forward part of the system for each bike. I'm sure the Yosh can on my wife's SV is the same as for the SuperHawk. It's just different from the can forward.
And by the way, to install the Yosh slip-on on an SV you have to hacksaw the stock muffler off. Not as bad as it sounds, but you do have to measure accurately.
Old Jun 25, 2009 | 08:28 PM
Circuit_Burner's Avatar
guru of things sparky
There a lot of flexibility after the midpipe.
But beware using just anything for midpipes, as the lengths between turns and the junction are pretty important to preserve, as they are specific for this motor. Lengths and locations are the most important factors in exhaust design.
You will find its possible to make a twin exhaust with no junction, but it probably makes less power...unless you totally luck out and get one resonating just right for the application.
Seriously, the echo link is damn important, dont mess with that part of the design unless you keep the basic lengths of the tubes right.
Old Jun 26, 2009 | 06:43 AM
malahhaor's Avatar
malahhaor is on a distinguished road
I was just thinking of same. wanted to put Yoshi cans tri-Ovals R-22 from Gixxer 1000 and cusom make connecting sections since they don't make that for the chicken, but found a cheap set of D&D slip ons for VTR so will go with that for now.
Old Jun 26, 2009 | 06:48 AM
Dnagmour's Avatar
Dnagmour is on a distinguished road
I'd like to hear more on this too. I'd like D&D's but want a high mount. I'd be willing to have mid's made if it'd do the trick.
Old Jun 29, 2009 | 10:14 PM
shayne's Avatar
No problem at all, as long as the new mid pipes are well made. If you wanted to do a top job on it, I would get a new collector made as well. The stock one is not very good. Have a look at any aftermarket headers to see what a good collector should look like.
I have FJR1300 mufflers on my bike.
Old Jun 30, 2009 | 05:02 AM
chickenstrip's Avatar
chickenstrip
Huh? Wha?
Old Jun 30, 2009 | 06:18 AM
You're in luck then, sort of...The chrome high mount midpipes from Jardine's round black powdercoat slip ons fit perfect with D&D mufflers. The hangers will work fine too. Only problem is Jardine stopped making them and you can no longer order replacement midpipes or hangers. You'd have to get lucky here or on ebay.
Old Jun 30, 2009 | 11:41 AM
opsmgr's Avatar
opsmgr is on a distinguished road
But beware using just anything for midpipes, as the lengths between turns and the junction are pretty important to preserve, as they are specific for this motor. Lengths and locations are the most important factors in exhaust design...
I was idly looking down the exhaust connector pipe the other day, and where the pipe exit joins on, there's a piece of pipe partially blocking the tube off where it comes out to the silencer. I think that's part of the exhaust tuning (probably giving a bit of back pressure) but it's quite a serious restriction in the stock headers...
Paul.
Old Jun 30, 2009 | 12:13 PM
Gregw's Avatar
Paul.
Not really. If you think about it, your going from a single pipe to two pipes of the same diameter, effectively doubling the volume. Minus the restriction, you're still about 1 1/2 to 1 3/4 more volume.
Old Jun 30, 2009 | 01:42 PM
Paul.
The restriction was a hot topic about 11yrs ago. When it is removed you do get a more even flow through both pipes but Dan Kyle showed (with back to back dyno runs) that you actually loose a bit of power when the restriction is removed...... but as always YMMV
Old Jun 30, 2009 | 02:37 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
For those that want to customise: I emailed Jardine recently and they offered to supply high mount midpipes for US$95 each plus shipping.
Old Jun 30, 2009 | 05:34 PM
Are those the stainless with springs or the chrome with clamps? I asked about a year ago and they said the chrome with clamps were no longer available because they had stopped production of the round black powdercoat system. If someone is ordering them be sure to clarify. Again referring to what fits a pair of D&D cans its the chrome mids that clamp on.
Old Jul 1, 2009 | 09:48 AM
Dnagmour's Avatar
Guess I'll order a set of D&D's and worry about the mids later. Thanks for the info!
Old Jul 1, 2009 | 10:03 AM
Dnagmour's Avatar
I think I'll email Jardine and see if I can get the specs on the chrome ones. At least whoever I have build them would have the right dimensions and bends.
Old Jul 3, 2009 | 07:24 PM
shayne's Avatar
Originally Posted by chickenstrip
Huh? Wha?
My Staintune mufflers came off an FJR1300, and I modified them to fit the VTR.
j shizzy wizzy
Feb 7, 2010 03:00 PM
mikstr
Mar 29, 2008 07:31 AM
102dals
Nov 17, 2007 10:22 AM
Auron
Dec 1, 2006 11:56 PM
Rollingalong
Feb 16, 2005 11:06 PM
