Dead Battery
Dead Battery
So last season my SH's batter started going dead once in a while. I thought it was just because the battery was old, so I replaced it. The next day that one was dead too. I checked all of the wires that looked like they could be shorting out and taped them but that did not work.
My friend owns a shop and said this guy has the same problem and it's his voltage regulator. Aparently the '98 model has this problem and he is going on his third. This time he is using an aftermarket regulator for an R-1. I'm waiting to see how it works.
Has anyone else had this problem?
Tends to be a common failure item on honda bikes.. I performed the r1 r/r mod earlier this week on mine as my r/r had died and smoked the connector as well. Search for regulator rectifier in the search tab and you will find plenty of info.
