correcting the hiccup with higher idle
Old Jun 18, 2010 | 10:56 AM
turbotim's Avatar
Stiff Member
turbotim is on a distinguished road
Will raising the idle fix the notorious hiccup? Mine idles at 1200 rpms & every once in a while it will hiccup but not stall. If raising the idle fixes this, can someone point me in the direction of where the idle "wheel" is. I'm assuming it is a wheel but don't know for sure. Thanks, Tim
Old Jun 18, 2010 | 11:07 AM
996Riders's Avatar
996Riders is on a distinguished road
to raise the idle you adjust the throttle stop screw which is located above the coolant box on the right hand side of the bike.. page 57 of the manual just in case..it wouldnt let me post the pic
Old Jun 18, 2010 | 11:38 AM
evines's Avatar
Raising the idle to 1500rpm didn't fix the hiccup for me. It might have limited the number of times the bike stalled after the hiccup, however.
Old Jun 18, 2010 | 12:39 PM
malahhaor's Avatar
malahhaor is on a distinguished road
My RPMs jump up and down at idle all the time and hiccups happen once in a while, my idle is set at 1500 to omit the bike stalling when hiccup happens but 1500 idle rpm does not stop hiccups.
Old Jun 18, 2010 | 12:53 PM
Start by synking your carbs... Then play with idle... Just raising the idle is like putting a bandaid on a broken bone...
zxbud
Feb 18, 2012 02:38 PM
lip81
Oct 30, 2009 06:05 AM
skoshere
Mar 23, 2009 07:56 PM
Letsrideinsc
Sep 13, 2008 06:47 AM
Jon87yj
May 20, 2008 09:09 AM
