cooling system question
Old Jan 22, 2009 | 05:50 PM
Truckinduc's Avatar
SO I just realized my bike is missing the entire thermostat housing. Im re doing my entire cooling system anyway so im wondering what adverse effects ill have by not running a thermostat.
I know it will take longer for the bike to fully warm up since the coolant is always flowing.
Ill be running 1 radiator under the tail of the bike instead of the stock dual side mount. The rad will have 2 86 cfm fans to handle the cooling duties. The fans will be hooked up to a 3 position switch. The 3 positions are OFF, automatic(electric thermostat controlled), and manual ON.
SO, what do you think?
Old Jan 22, 2009 | 05:57 PM
http://cgi.ebay.com/ebaymotors/97-05...spagenameZWD1V
$10
Old Jan 22, 2009 | 06:29 PM
Little_Horse's Avatar
2nd mouse gets the cheese
the thermostat assembly also houses a sensor that wires back into the ignition control, I am not sure if that will affect ignition issues or not but something to think about.
Old Jan 22, 2009 | 06:32 PM
kai ju's Avatar
So what do I think ?
Oh Yeah, another one.
I would run the thermostat, it'll provide more consistent cooling temps.
I don't know what the cfm rating is on the stock VTR pusher fans, but I'm running two.
They are both thermostatically controlled.
The first fan, which has an adjustable switch, cycles between 207 and 203.
The second fan cycles between 208 and 194 deg F and is switched by the original fan switch.
When the thermal load causes the temp to stay above 208 deg F, the second fan kicks in.
I'm going on three years running the underseat radiator, the last two years with two fans.
I only had an issue with almost overheating the first year when only running one fan.
(chasing a buddy in 100 deg temps at 100 plus speeds through central California on the way back from Laguna Seca)
Since I've gone to the two fan set-up the bikes runs cooler than an RC51 or VTR.
Also be aware that riding in the rain, the water coming off the rear tire, even with a hugger, water cools the radiator and the thermostat never fully opens.
Go for it.
Kai Ju
Old Jan 22, 2009 | 08:03 PM
Truckinduc's Avatar
so I think Ill try it without the thermostat. Ill have less overall coolant than the stock setup which might help bring the temp up.
Old Jan 22, 2009 | 10:08 PM
RK1's Avatar
RK1
Thermostat is fully open by 165-170 degrees, so other than taking a bit longer to fully warm up, I don't think running without a termo makes any difference.
Old Jan 22, 2009 | 10:27 PM
Texassuperhawk's Avatar
Texassuperhawk
I plan on doing the undertail radiator too, if you decide youwant a thermostat let me know , I have a spare you can have, just cover the shipping.
Old Jan 23, 2009 | 01:00 AM
I ran no thermostat for months half summer (90+) & half winter (18-) & was amazed that it did not make that much difference. It made way more diff on my cbr but the front rad is a diff setup. The vtr doesnt ever seem to be able to "over cool" itself like a front rad bike in winter can.....
Old Jan 23, 2009 | 04:01 PM
Truckinduc's Avatar
I think it may run close to stock temps due to the fact ill have 1/2 the radiator surface area, and about half the original coolant volume.
Old Jan 23, 2009 | 04:05 PM
hawxter996's Avatar
ole dirty bastard
i may be wrong but i think the ignition pulls timing as the coolant gets warmer.
Old Jan 23, 2009 | 07:27 PM
RK1's Avatar
RK1
I think you'll be running hot with or without the thermostat.
All the thermostat does is withhold coolant flow when the coolant on the engine side is below 169 degrees F.
Unless you're riding in sub freezing temps, the thermostat only matters for the few minutes between cold start and and 169 degrees. After that I don't think it matters one whit whether the thermostat is installed in the bike or sitting on a shelf in your garage.
fred
Aug 2, 2010 07:50 PM
RWhisen
Jun 7, 2010 09:54 PM
steve29
Feb 24, 2010 07:25 PM
reaper
Sep 2, 2007 09:29 AM
Speed_Demon
Feb 2, 2006 05:52 PM
