cooling system, fan won't kick on
Old May 8, 2012 | 04:13 AM
Bandit400man's Avatar
Bandit400man is on a distinguished road
Anybody have an ideas as to why the fan wouldn't come on? Got the coolant filled an bled I believe, following this site an the service manual. I start the engine, let it idle...temp rises an rises, gets past middle point on dial an keeps climbing. No fan. Thermal protection eventually shuts off the engine. Fan is plugged in, fuse is good.
So what's my next move?
Old May 8, 2012 | 06:31 AM
BeerHunter's Avatar
Slacker
Have a look at chapter 19-18 in the service manual. I believe there is a ground wire coming off the connector near the fan motor. It could have been left unbolted or loose. Corrosion at the ground would also cause the fan to not work. Also, the fan switch may not be connected or faulty. It closes the circuit on the ground side.
I may be uninformed, but I do not know of any thermal protection that will shut the engine down from overheating.
Old May 8, 2012 | 08:18 AM
Yeah, def thermal protection cause the first time I just let it go to the red zone an it shut down automatically...a lot of bikes have it in case the thermostat or whatever fails...
But ok thanks for the advice...that's where I'll start when I'm off work
Old May 8, 2012 | 08:21 AM
BTW a lil back info, never had this problem till I removed the clutch cover to replace the gasket behind it...had to remove right fairing an that sensor bolted into the cover cause I couldn't locate the other side to unplug it...
Old May 9, 2012 | 09:32 AM
It was the Fan thermo switch. Found out after beerhunters advice...an burning the living **** outta my fingers when I jumped the wrong plug to the frame with a twist tie lol
Old May 9, 2012 | 09:42 AM
RWhisen's Avatar
Former Superchicken Owner
HAHAHAHA Those twist ties heat up pretty quickly don't they?
Old May 9, 2012 | 03:55 PM
Yeah...****** got red hot befor the pain even registered LOL...lucky for me I got tons of vichoden for when my buddys 4wheeler crushed my head and fractured my skull...
Old May 9, 2012 | 04:06 PM
OUCH! Anyway don't feel bad my brand new superhawk back in '99 overheated with 50 miles on it the day it came out of the crate because of a faulty fan switch.
Old May 9, 2012 | 04:10 PM
Ohhhh...so its lika...thing huh? LOL Yeah I coulda swore I didnt fudge it up or anything...like, WTF? LOL an there expensive too! Ron wanted @$45 after shipping...that's an OUCH! LOL
LC4CARL
Sep 1, 2009 12:31 PM
Misspent Youth
Sep 25, 2008 02:54 PM
Flying Dutchman
Apr 1, 2008 05:26 PM
SuperHawkins
Nov 1, 2007 06:41 AM
RickB
Sep 13, 2005 09:05 AM
