clutch wont engage
Old Jan 20, 2010 | 09:11 PM
kenhawk's Avatar
Junior Member For Now
kenhawk is on a distinguished road
clutch wont engage
As the title says...
There is clutch fluid and i think i bleed any air out...
When I try to put it in gear it will just die...
Any thoughts?
Thanks!
Old Jan 20, 2010 | 09:18 PM
Did you do something suddenly that would require bleeding the clutch? You don't sound too sure Is the lever dead/soft or does it feel proper-as it would if were bled completely? Did this happen suddenly or over time or did you take stuff apart or what? When was the last time the bike ran properly and what happened in between then and now? A little more info could probably help folks help you better.
Old Jan 20, 2010 | 09:25 PM
Little_Horse's Avatar
2nd mouse gets the cheese
what about the side stand switch, if it dies when you put it in gear but does not lurch forward its the side stand switch.
Old Jan 20, 2010 | 09:37 PM
Sounds like the side stand is down to me or the switch like cornandp stated.
Old Jan 20, 2010 | 10:17 PM
kenhawk's Avatar
Thanks guys,
I will check out the switch and if not ill give all the details!
~Ken
Old Jan 21, 2010 | 04:25 AM
stebbdt's Avatar
COBB Member
Yeah, I do occasionally forget to lift the stand in the early am. At least I don't find out on that first lefthand sweeper just down the road lol
Old Jan 21, 2010 | 11:46 AM
That's why they do it.
Old Jan 21, 2010 | 11:55 AM
mhaisten's Avatar
Wrench Bender
Years ago I did it on a friends 600 Ninja. Big fast sweeping left. Right off the side of the road. You can take away the switch on my bike because I will NEVER forget that again.
Old Jan 21, 2010 | 12:03 PM
spladle160's Avatar
Sometimes the master cylinder won't release fluid back to the resevoire because the return valve is absolutely tiny and is easily clogged by debris and corrosion. If there was/is old fluid in there it could be that this is the problem. An easy test/ temporary solution is to bleed a tiny bit of fluid from the slave cylinder, this will allow the excess pressure to dissapate and the clutch to engage. I rode for 2 weeks with a 10 mm wrench in my pocket
Old Jan 21, 2010 | 01:21 PM
Hawknut's Avatar
Hawknut
More info please.You mentioned clutch so I assume that it just does not shut off-quit running.Does it lurch ahead and stall?Have you done anything to the bike or did this just happen.If it did just happen-try this.Key OFF,clutch squeezed,1st gear engaged,rock bike back and forth and see if you can get the bike to move.If it breaks loose and moves it could be the said stuck clutch plate syndrome---it happens.Try your normal I want to go for a ride thing.If you can't get it to move and your clutch lever is real spongy,you have a problem.Help us help you---More Info.Please--One more thing.Tell us what you find.
Old Jan 21, 2010 | 01:49 PM
Yeah it only takes once to add "Side Stand Up" to your starting routine......
It's the step before "turn ignition on" for me as I had pretty much the same experience....
Old Jan 28, 2010 | 09:52 PM
Third Echelon's Avatar
Third Echelon is on a distinguished road
I had the same problem, you gotta bleed it at the slave cylinder as well as the master. pull the clutch with your left hand, loosen the nut at the end of the chamber where the line comes out, you should get a puff of bubbles, tighten, rinse and repeat. bobs ur uncle
Mr.Lojo
Feb 7, 2015 02:48 PM
BigJMerc
May 4, 2011 12:14 PM
shake-n-bake
Mar 20, 2011 10:50 PM
thusspakebenji
Jul 23, 2010 07:53 AM
cb21983
Jul 16, 2005 10:24 AM
