Clutch Slave Cylinder Leak - common problem? easy fix?
Old Jul 27, 2010 | 02:48 PM
98VTRrider's Avatar
I noticed my clutch fluid looking low, then I put the kickstand down and saw a drip come from the slave cylinder. I haven't found much after searching for slave cylinder leaks. Is this a common thing? Is it an easy fix?
My friend told me to take it apart and clean everything really good, then put it back together and see if it stops. He said he had a leak and did that and it stopped leaking. I'm going to try this and see if it helps. Does honda sell a rebuild kit?
Old Jul 27, 2010 | 03:11 PM
Not super common but it happens.
I had what I thought was a leak when I bought my sued SH in 2005.. Turned out to be chain lube that had built up and was dripping down.
Another SH I was asked to help with did have a leaking slave cylinder seal.. and the MC was rebuilt at the same time.
Honda does not sell a kit, you just buy the parts required.
Old Jul 27, 2010 | 03:14 PM
Well you can just remove the piston and clean everything. There isn't a rebuild kit per say as there is only one seal and a spring in there and it's only around $12 if you replace both of them. So if you are going to pull it apart I would replace the seal just because....
http://fiche.ronayers.com/Index.cfm/...VER_WATER_PUMP
Old Jul 27, 2010 | 03:18 PM
GSKT, SLAVE CYLINDER
Mfg. Part Number: 22862-MW7-650
Price: $3.91
CUP, SLAVE CYLINDER
Mfg. Part Number: 22865-MJ8-003
Price: $7.70
SPRING
Mfg. Part Number: 22864-MT7-016
Price: $4.31
OIL SEAL (8X18X5)
Mfg. Part Number: 91209-MB0-003
Price: $2.81
From Ronayers.com
Old Jul 27, 2010 | 03:24 PM
Well there is really no need for the "oil seal" as that is where the push rod mates to the slave cylinder. All you really need is pos #9 the cup,piston. The spring is something I replace while in there "just because"
Old Jul 27, 2010 | 08:41 PM
98VTRrider's Avatar
What a Mess!
So I pulled the slave of tonight, and it's nasty.
I'm going to assume the fluid was never changed in my bike, what came out looked like chocolate milk.
Big pile of krud inside the cylinder.
I cleaned everything as best I could and put it back together, then flushed half a bottle of fluid through it before it cleaned up. I think I'm going to order the piston cup/spring/gasket, and maybe a SS clutch line too I'm sure my line is full of dirt. (another reason to upgrade )
After bleeding the clutch felt really smooth like it was moving more freely, go figure. Went for a short ride and don't see a leak, I'll go for a longer ride tomorrow and see if it leaks.
Old Jul 27, 2010 | 09:02 PM
Yeah that is pretty nasty.....
Old Jul 27, 2010 | 10:22 PM
98VTRrider's Avatar
Just ordered all parts, including SS line . Thanks E.Marquez & 8541Hawk for the links, that's where I ordered them.
Old Jul 28, 2010 | 03:02 AM
Wicky's Avatar
Examine the inside of the cylinder surface closely for scratches from grit in the crud. I replaced the slave seal and continued to have a slow leak. Some fine wet&dry and a polish put that right.
PS The Blackbird's slave cylinder is exactly the same
Old Jul 28, 2010 | 06:25 AM
98VTRrider's Avatar
yea I was worried about that when I was cleaning it, looks like the cylinder was worn pretty good. When I get off work I'll go on a long ride and see how it does.
Old Dec 21, 2010 | 02:14 PM
living the dream's Avatar
living the dream is on a distinguished road
help on clutch master cylinder assembly
hey guys..im new to the site just got a superhawk..
sorry for bringing an old thread to live but i need a little help..
i got my superhawk off a friend and when i got it the clutch was broken off..got a a new clutch lever and realized the bushing and push rod for the slave cylinder were missing..i did some looking online and went to a local honda shop $30 dollars for those two parts, that will not work with me. soo i have decided to just make one.. i was curious as to if someone can give me the dimensions to the pushrod and bushing as to the length of the push rod and the diameter of the slug end that pushes against the piston..if i can get those dimensions the bushing that goes into the lever that holds the push rod in place would be an easy make..any help i can get would be most apperciated..if anyone could pm me those diamension or help on were to find a cheap set it would really help..
thanks for your time guys
Chad
Old Dec 21, 2010 | 04:44 PM
You can get both of around $18 here:
http://www.hondapartsline.com/fiche_...1998&fveh=4077
Old Dec 21, 2010 | 07:15 PM
thanks alot apperciate it..still gonna try and make one kinda bored and easy process..
but again thanks for your time
Old Jun 1, 2011 | 10:20 PM
Onomea's Avatar
SportTouring
Great thread/advice. Just what I was looking for. I don't post much just learning a
whole lot from you guys! Thanks!!
Old Jun 2, 2011 | 05:53 AM
98VTRrider's Avatar
glad it helped...good info is what makes forums like this so good, and the dedication of true members
HawkRider98
Aug 16, 2013 05:41 PM
mikstr
Jan 7, 2011 08:00 PM
Streaky
Apr 19, 2010 08:24 PM
trinc
Mar 18, 2009 10:47 PM
nineighthawk
Apr 26, 2007 10:04 PM
