Clutch Replacement..
Old Jun 26, 2007 | 08:48 AM
VTRFan's Avatar
VTRFan is on a distinguished road
Hey all, was curious if anyone has had any experience replacing the clutch themselves, mine is toast. It is rideable, but it will not do wheelies and there is a lot of play in the clutch lever ( Must let it out all the way before it starts to go) Im pretty sure its the clutch but could be wrong if anyone else has had the same problem...thanks
Old Jun 26, 2007 | 10:25 AM
XLSR-VTR1's Avatar
XLSR-VTR1 is on a distinguished road
Changed mine, was easy. The hydraulic clutch engages at the end of the lever anyway. I believe there is a spec for the clutch plate thickness too, just have to replace the side cover gasket but if your going to the trouble to check it, just replace it.
But Id bleed your clutch first... theres another thread on this and I think someone said to bleed it 2-3 times... Try a set of Barnett springs too, I didnt notice much difference in lever pull difficulty but it doesnt slip or hasnt.
https://www.superhawkforum.com/forum...ead.php?t=6060
Old Jun 26, 2007 | 11:06 AM
superbling's Avatar
Get or download the manual. Other than having to drain the coolant, it's a pretty straight forward operation if you are only changing out plates/discs/and springs.
One word of warning: be very careful installing the engine cover as the waterpump shaft must seat properly or you can break it off. BTDT. Don't forget a new gasket for the engine cover.
Old Jun 26, 2007 | 11:20 AM
XLSR-VTR1's Avatar
Yes, that too and oh, loosen and tighten the 6 bolts that retain the clutch a few turns each at time, dont take each one out completely in one shot or you could cause damage to the cover from the uneven spring load on the basket cover.
Old Jun 26, 2007 | 11:25 AM
VTRFan's Avatar
Awesome! thanks guys, that doesnt sound bad at all. I need to just stop talking about it and pull it apart on a weekend and get it done, how much does everything cost for this job, ive not checked....and how long should this take me to do it?
Does anyone know were i can download a manual?
Old Jun 26, 2007 | 11:46 AM
XLSR-VTR1's Avatar
there was a link to a manual as a sticky on the discussion page I recall...
Ive been getting prices from this web site. I should get a royalty for plugging them so much! lol
http://www.hondaparts-direct.com
Old Oct 19, 2007 | 03:14 PM
call me phil's Avatar
call me phil
vtr fan....was wondering how you made out with the cltuch as i am experiencing the same problems and was curious to see if replacing the clutch solved your problem.
patience
Motorcycle News
Apr 13, 2010 10:31 AM
NCDave
Nov 30, 2009 01:20 PM
acarp
Sep 20, 2009 11:14 PM
caffeineracer
Sep 23, 2005 06:27 PM
ali_squidz
Sep 7, 2005 04:17 PM
