Clutch nut fubar
Old Oct 20, 2017 | 06:29 PM
T-roy's Avatar
T-roy is on a distinguished road
Clutch nut fubar
Went to unstake the clutch nut and it was staked all the way into the key way. I tried to drill it out and broke the bit off in the key way along with the original stake job....
Please help!!!
Old Oct 21, 2017 | 12:18 PM
Please help!!!
Please take a few well lighted in focus pictures from several angles
Old Oct 21, 2017 | 03:07 PM
Old Oct 21, 2017 | 05:07 PM
T-roy's Avatar
Old Oct 22, 2017 | 07:40 AM
If that were in my shop, I would pack that side of the motor with paper towels , spray said towels with WD40 to help stuff stick, then put a carbide bur in an air motor and carefully cut away the nut and such at the point of issue. When you have removed what you think is enough, try and loosen the nut.. me Id use my SO MG725 impact on full blast ...after that you will have to dress up the last few threads and keyway, and use a new nut of course.
Id bet it would take me longer to put the paper towls in and spray um down than get the nut off.
A Dremel and a few grinding stones would work as well...just puts a ton of abrasive in the area where the carbide but just makes metallic "chips" that will mostly be caught in the towels and the rest can be picked up with a magnet.
If you use the grinding stone,,,,,,, I would suggest you have ready a few cans or brake clean and or kerosene some type of sprayer and flush that side of the motor well, changing the oil AFTER you do that. Then change the oil and filter again after just one long ride.
ZERO
Jan 12, 2016 06:13 AM
jibbs
Oct 14, 2011 02:44 PM
shelcon
Sep 24, 2007 10:19 AM
superhawk22
Jun 5, 2007 04:43 PM
Ysabel
Feb 18, 2007 07:08 AM
