clutch going bad...? i hope
Old May 28, 2007 | 11:41 AM
joshn569's Avatar
joshn569 is on a distinguished road
Thumbs down clutch going bad...? i hope
ok so a few days ago i noticed a clunk sound when i let my clutch out when taking off. it happend when about 3/4 out. it was only happening in first gear. now a few days later i makes 2 - 3 clunks and happens in 2 gear when leting the clutch out after my shift. I suspected the clutch was going bad, but its not slipping when in the high r's. Im thinking maybe some broken plates in there>? any one else ever had a simular prob? what did it turn out to be? I dont have a gasket right now or else i would look in there.
Old May 28, 2007 | 02:54 PM
Motohead's Avatar
Motohead
Never had it happen, but it could be broken frictions or notching on the hub and/or basket keeping the frictions and steels from sliding smoothly (popping in/out of place). I'd pull the cover and take a look as soon as you can. Don't forget to drain the oil first.
Old May 28, 2007 | 10:24 PM
notaduc's Avatar
notaduc is on a distinguished road
Possibly the cush bushings in the rear wheel? Pretty easy to check before tearing in to your clutch assembly....
Just a thought...
-Jon
Old May 29, 2007 | 02:59 AM
gboezio's Avatar
You can have a peek trough the oil cap, you can see if the drum is notched.
Old May 29, 2007 | 03:55 PM
joshn569's Avatar
its def. comming from the clutch cover. cant see any thing out of the ordinary when i look in the oil fill cap.
Old May 30, 2007 | 07:28 AM
Motohead's Avatar
Motohead
Give the clutch lever a few slow pulls while looking down into the fill hole. See if you can see any binding.
Old May 30, 2007 | 08:11 AM
gboezio's Avatar
Well get a gasket set and a case of beer, time for inspection.
Old May 30, 2007 | 10:01 AM
L8RGYZ's Avatar
Watch for the blurred vision thing.
outrigger
Mar 17, 2013 06:14 PM
kardiac996
Sep 27, 2012 09:51 AM
Wolverine
Sep 14, 2011 08:29 AM
Ogre8472
Oct 31, 2006 09:05 PM
spacemonkey
Sep 15, 2005 06:38 PM
