Clutch cover wont mount after chain change
Old Apr 30, 2011 | 04:22 PM
BigJMerc's Avatar
BigJMerc is on a distinguished road
Hi guys I have been reading for awhile but never have posted and have learned a lot since getting my hawk last year. I was changing the chain this weekend and unfortunately forgot to zip tie the clutch lever. When trying to put the clutch cover back on the the clutch lifter rod seems to not go in all the way. I bleed the lines and opened up the slave cylinder and cleaned the piston. Still cant get the clutch cover to bolt in the rod sticks out to far. Any ideas on what else I should try?
Old Apr 30, 2011 | 09:57 PM
Ensure the actuating rod is fully seated on the clutch side. In my experience, you have to push the slave cylinder almost all the way in if you want it to mount straight up. Otherwise, if you can get one or two cover bolts started then it will push the slave cylinder in as you tighten the cover.
Old May 2, 2011 | 10:33 AM
BigJMerc's Avatar
Thanks I will give it a try tonight
Old May 4, 2011 | 12:14 PM
BigJMerc's Avatar
I was able to grab two longer bolts from the store then tourque on the cover and it works, thanks a lot for the help hawk. I will try and get some pics of my bike posted up here soon
Mr.Lojo
Feb 7, 2015 02:48 PM
Johnbain
Jan 2, 2012 05:48 PM
Tempest
Sep 20, 2006 07:35 PM
NOrrTH
Nov 25, 2005 09:59 AM
sckomar
Aug 9, 2005 07:23 AM
