Clear Tails
Old 08-27-2009, 11:50 PM
notquite's Avatar
notquite is on a distinguished road
Clear Tails
I just ordered a set of integrated lights from volar motorsports. I gotta say, Man they look great...till you turn them on. They are not as bright as I hoped. Can anyone tell me if Clear Alternatives Brand is any brighter?
notquite is offline
Old 08-28-2009, 03:16 AM
Billzilla15's Avatar
i don't know how much brighter they are than the ones you got, but i have the clear alternative integrated one on my bike and i am very happy with it
Billzilla15 is offline
Old 08-29-2009, 12:44 AM
shayne's Avatar
My Clear Alternatives light uses standrad globes, and it works fine as you would expect.
shayne is offline
Old 08-29-2009, 06:03 AM
Originally Posted by shayne
My Clear Alternatives light uses standard globes, and it works fine as you would expect.
Umm, standard globes?
You must have a different Clear alternative light then the rest of us.. As all the ones I've seen here and the one on my bike are LED. They do not use "globes"
http://clearalternatives.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CA&Category_Co de=VTR1000
To the OP.
My opinion,, they are not bright enough unless it's not full sun out.
I've had mine for 1.5 years or so now.. Added extra turn signals on it so others could tell where I was going. The combo of flashing LEDs in the turn signal/stop light and some low profile turn signals that are under and at the sides of the under tail work well.
I'm changing back to the red stop light as soon as I get back to Texas again.
E.Marquez is offline
Old 08-29-2009, 07:15 AM
kmm996's Avatar
kmm996
My Clear Alternatives use the LEDs. Seems to be much brighter than stock.
kmm996 is offline
Old 08-29-2009, 09:57 AM
Be sure you're taking into consideration the average height people will be viewing your taillight from their cars. If you're standing directly behind your bike it may looks dim, but crouch down and view it like your in the drivers seat, much brighter down there. Also there is a plastic tab on the backside of the housing, there is supposed to be a rubber dampener on that (should look like a small piece of rubber hose. That piece not only helps out with vibration, but it also pivots the taillight housing up some.
To try and answer your question, I bet the same Chinese factory makes the cheap eBay unit you bought and the overpriced Clear Alternatives unit.
Does the Clear Alternatives unit have built in turn signals?
inderocker is offline
Old 08-29-2009, 11:17 AM
notquite's Avatar
To the OP.
If you have CLear alt's brand and want to sell or swap to stock give send me a pm.
notquite is offline
Old 09-02-2009, 12:41 AM
shayne's Avatar
To the OP.
Possibly. Mine does not have the integrated turn signals, it is brake and tail light only. It definately uses normal globes, not LED's.
shayne is offline
Old 09-02-2009, 02:19 AM
aka sirch345. vtr1000.org
ripvanwinkle's Avatar
ripvanwinkle is on a distinguished road
You're spot-on there IMHO! Other vehicles at different heights wont see them so well as the standard bulbs!
I had LED indicators on the rear, but have now reverted back to the original.
Admittedly I preferred the look of the LED ones, but for me now safety comes first.
As you say with LEDs you need to be in line with them to get the maximum brightness in view. Even looking at them slightly to either side of the centre line they're not so bright as the original bulbs.
ripvanwinkle is offline
Old 09-02-2009, 06:53 AM
Gregw's Avatar
Mostly that is the case. The Luxion LEDs I put on my bike are very bright off axis. Here is an example. Note the even with a camera flash they're still bright.
Gregw is offline
Old 09-02-2009, 07:07 AM
That has very little to do with actual brightness and are more due to the fact that the Luxeons have a lense fixed to them giving them (I believe) a 110 degree viewing angle...
Same for the LED module that haknslash and others including me have used... The 10 LED's there each have an individual lense behind the outer shell (could be integrated into it, dunno...) that give a good viewing angle and it can be clearly seen from any vehicle height...
Tweety is offline
Old 09-02-2009, 08:34 AM
Stevebis1's Avatar
I'll chime in here - the LED turn signals on my mototech undertail are very directional and because of the undertail design they "shine" about 30 degrees to each side. I never realized how invisible they were untill I rode with others who thought I was not using my signals at all.
I added an Ebay clear alternatives knock off. It is focussed faily narrowly also, but the combination of the undertail signals and the integrated tail light gives me decent coverage.
I have not seen a real Clear Alternatives tail light. If it really gives a full coverage pattern it is probably worth the price. Checking the threads here no one has indicated that is the case
Stevebis1 is offline
seaton001
03-19-2007 05:46 AM
Radiaoktiv
11-17-2006 12:54 PM
iamanonymous
09-05-2006 12:56 PM
CNI Dawg
06-08-2006 07:28 PM
mikecronis
04-16-2006 12:10 PM
Quick Reply: Clear Tails
