Choke pin won't stay
Old May 24, 2010 | 12:02 PM
Anwar's Avatar
Anwar is on a distinguished road
I got a question
On my 98 SH the choke pin used to stick all the way out and stay there, about 3 weeks ago, but now the choke doesnt stay open enough and I have to hold it about half way open. When I let go it slides slightly in and the engine flutters.
Also last night Iw as letting it warm up, and it reached the 1/4 way mark and wasnt ready yet, and i ending up taking off when it reached half temp.
Is this bad or can I tighten the choke somehow?
Also, how can I check for a bad CCT?
Old May 24, 2010 | 12:08 PM
To tighten the choke, lift up the rubber cover under the **** and tighten the adjuster, then put the rubber cover back in place.....
Old May 24, 2010 | 12:11 PM
The rubber right behind the choke **** pulls off to reveal the adjuster for the tension to prevent just that.
pic & description available on Greg's page: http://www.superhawk996.net/index.html
Go to:
VTR1000F
->Performance & Mods
-->Adjusting Choke **** Tension
Old May 24, 2010 | 12:13 PM
mboe794's Avatar
Mine used to be sticky as hell. Sometimes it was hard to tell if it was operating correctly because of it. I removed the entire cable assembly and lubed it all very well. Too well. Now it wont stay out! Tightening that adjuster did little or nothing for me. It is about as tight as I feel safe turning it right now. I'll just have to hold it out I guess.
Old May 24, 2010 | 12:15 PM
Sounds to me like you lubed the tension plastic as well as the cables..
There is such a thing as too much lube.
Old May 24, 2010 | 12:20 PM
Anwar's Avatar
Whoa, thanks alot!
Also, would you have any semi-simple advice for checking for a bad CCT?
Old May 24, 2010 | 12:26 PM
Unfortunately there isn't one. When they go bad it happens all at once, just like a timing belt on a car it will be fine right up until it breaks and damages the engine. Thus like a timing belt, you replace it before it goes bad.
Old May 26, 2010 | 06:02 AM
alientestsubject's Avatar
Fading Fast
alientestsubject is on a distinguished road
small trick
my superhawk does this too. i didnt know there was a adjuster. im going to check that when i get home tonight. i took a piece if rubber hose 1/8" ID cut it 3/4" long and cut it down the side. i pull out the choke **** and slip it over the metal shaft. it holds the choke open. just need to be there when the bike starts to idle fast.
Old May 26, 2010 | 05:01 PM
comedo's Avatar
Dear mboe794,
I'm in the same boat. I've learned to live with it. Maybe I'll get a new choke cable when I do winter maintenance.
Old May 26, 2010 | 07:41 PM
superh1998's Avatar
Mine used to do it as well...As stated above, all you need to do is remove the rubber cover and tighten the plastic ring.
It solved the issue on my bike.
Old May 27, 2010 | 02:50 AM
Fading Fast
done deal
worked like a charm! this website is the berries
Old Sep 1, 2011 | 10:01 PM
lip81's Avatar
lip81 is on a distinguished road
sweet so easy!!
Old Sep 22, 2011 | 08:10 PM
mertechperformance's Avatar
MandownMertech
This forum is full of the good stuffs, random lil things like this, so awesome.
Old Sep 22, 2011 | 08:27 PM
Cafe Racer's Avatar
King of this hill
Okay...I'm starting to get a tooth ache. This thread is getting to sweet.
Jul 20, 2010 03:00 PM
Crashrat
Dec 13, 2009 07:17 AM
rhorsley
Oct 31, 2008 08:48 AM
neilb
Sep 10, 2007 04:49 PM
Randman
Jun 29, 2006 02:06 PM
