Choke, cough, sputter!
Old Apr 29, 2019 | 07:12 AM
Unzie57's Avatar
Unzie57 is on a distinguished road
My 98 SH will run great for about a minute but then starves for fuel...until I give it a lot of throttle. Then it will run OK for a bit again. Hole in the diaphragm? What is the easiest way of draining the tank to take off the fueling valve?
Old Apr 29, 2019 | 07:19 AM
cpl rampage's Avatar
cpl rampage is on a distinguished road
Close the valve before taking the tank off, and then hang tank off the edge of a chair, and connect a short hose into a fuel can, open the valve and let it drain. Due to the location of the valve, you may have to slosh it a little to get the last of the fuel. Even then there will be leftover, just keep the tank upside down while you have the valve removed.
Old Jun 4, 2019 | 09:56 AM
Shoarmadude's Avatar
Shoarmadude is on a distinguished road
Ive raised the tank, put it on a stack of tired. Than used some fuell ine and put one end in the tank and the other in a empty can, sucked the fuel line and there you go
Old Jun 4, 2019 | 07:21 PM
CaryDG's Avatar
JIGGLER! Quickest, easiest siphoning device I've ever found! Amazingly simple and fast. I got it at HD in the plumbing department. $10.
residentg
Jun 17, 2021 04:37 PM
rickheel
Jan 1, 2016 04:36 PM
CruxGNZ
Feb 24, 2013 05:48 AM
milo2
Mar 30, 2012 02:44 PM
storm_rider
Apr 23, 2010 04:58 PM
