Chassis setup
Old Feb 6, 2012 | 07:43 AM
jay956's Avatar
Chassis setup
Since my Superhawk is going to my track toy this year I want a good base line to start from before I start messing with geometry. My bike has never been stock so I don't have anything to refer to. I found the shock length, 345mm, in an old thread. Can anyone tell me how much the forks are above the triple in stock form?
Old Feb 6, 2012 | 08:22 AM
On the OEM forks, there is a snap ring at the top.. The fork tubes are placed in the clamps till the stopper ring is against the top, of the clipon. Off the top of my head it's about 5mm of tube above the clipon.
Old Feb 6, 2012 | 08:54 AM
jay956's Avatar
5mm would be too little to put clipons on, you sure that's right? Or do you mean drop the forks until the stopper touches the top on the stock clipons, not the triple clamp?
Old Feb 6, 2012 | 09:26 AM
Yep ^
Old Feb 6, 2012 | 09:31 AM
Yes, that is what I meant
Old Feb 6, 2012 | 09:32 AM
jay956's Avatar
Thanks. Now that brings the question of how tall are the stock clipons? I have vortex clamps.
Old Feb 6, 2012 | 01:56 PM
RCVTR's Avatar
You really need to strongly consider new springs in the forks. The stock, progressive springs are too soft in the top of travel, so you can't set your sag properly, and you are likely to run out of travel on the brakes on a track.
Old Feb 6, 2012 | 03:04 PM
jay956's Avatar
If that was directed at me my forks are completely worked by Jamie, springs, compression valve, and rebound valves. I want to get the geometry to a base setting before tuning the suspension.
Old Feb 6, 2012 | 03:47 PM
RCVTR's Avatar
OK. that's good!
See if you can get somebody with a proper setup to give you a measurement from the top of the front axle to the bottom of the frame headtube, with the forks fully extended (front wheel off)
Old Feb 6, 2012 | 03:54 PM
jay956's Avatar
For top out springs?
Old Feb 6, 2012 | 04:28 PM
RCVTR's Avatar
So that you can set the forks at the proper height in the chassis, since you don't have stock triple clamps.
You will probably want to start at the stock height, for stability and to keep from rubbing hard parts on the asphalt.
Do the triple clamps have the standard offset? I think the std offset is 35 mm on the Super Hawk.
30mm is stock on an RC51.
Old Feb 6, 2012 | 04:30 PM
jay956's Avatar
Oh sorry, I do have stock triples. I was referring to the Vortex clipon mounts.
Cadbury64
Aug 13, 2015 02:44 AM
8541Hawk
Dec 19, 2011 11:45 AM
RCVTR
Dec 9, 2010 08:12 AM
KC-10ENG
Aug 21, 2007 04:26 PM
seaton001
May 8, 2007 12:45 PM
