Chain Lube
Old Jan 13, 2007 | 02:40 PM
Dave Wicks's Avatar
Dave Wicks is on a distinguished road
Chain Lube
Last chain drive I had was 1978 KZ 1000..Question..what's the chain lube of choice...looked at chain threads..didn't find any mention..What are you guys using???.what does a Scotoiler put on??
Thanks
Old Jan 13, 2007 | 05:28 PM
Corona Hawk's Avatar
Corona Hawk is an unknown quantity at this point
Chain Lube
I use MotoLine Synthetic chain lube. My driveway is .2 of a mile long (dirt) so I can't use the wax base lubes, which I prefer. There are other snythetic lubes available besides MotoLine.
Old Jan 13, 2007 | 05:43 PM
sprhawk neil's Avatar
I've used maxima chain wax for 2 years and like it sticks on the chain real well = no fling off not much mess
Old Jan 13, 2007 | 07:55 PM
HRCVTR1000's Avatar
maxima chainwax also , on the dirt & street bike ,sticks to the chain real well and dirt doesnt stick to it .
Old Jan 13, 2007 | 08:04 PM
Dave Wicks's Avatar
Chain Lube
Thanks guys.. I've never used a chain "wax"..Curious to see what is in it.. I've seen that Brand around.. I'll check it out...
Take Care
Old Jan 13, 2007 | 08:19 PM
Brian A's Avatar
PJ 1 Clear synthetic. It gets very tacky and does not sling off.
I generally use oil and/or WD40 to "wash" my chain once or twice a year, let it dry overnight, then spray on the chain lube.
Works for me.
Old Jan 13, 2007 | 08:22 PM
superbling's Avatar
I've read about tons of stuff after joining the net and hearing all kinds of opinions. I tried many but I only like:
WD40- cheap and is really just a cleaner/light oil. I prefer to use it on long trips to conserve tankbag space.
Honda HP chain wax-goes on gray and doesn't fling much.
Motorex 622 strong -goes on like an ultra sticky white grease like what's on a new chain. Over application will fling
Dupont teflon-current fav, a dry teflon lube so chain stays cleaner longer with very little fling.
I use kerosene to clean. I've never understood using WD40 to clean then apply a chain lube. How is the lube going to stick to an oily chain?
One of these day, I'll bite the bullet and get a $$$ scottoiler and not worry about it.
Old Jan 13, 2007 | 09:29 PM
+1 on the Scottoiler. Never clean your chain again and it'll last twice as long. My stocker lasted 25000 miles and I only changed it because the sprockets were getting a little worn, mostly the front one.
Old Jan 14, 2007 | 06:33 AM
Brian A's Avatar
WD40 is not, technicaly speking, a lubricant. It is a moisture displacer.
Hence the name: Water Displacement 40. Not sure what the "40" means.
Anyways, once applied and left to dry, the petrolum based carrier evaporates and the chain is left pretty clean and dry.
My chain lube sticks great, and my chain seems to be lasting a long time.
I really think most anything that does not break down the o-rings would work just fine.
Old Jan 14, 2007 | 06:50 AM
killer5280's Avatar
I used to use chain wax, but now I like Silkolene Pro-Chain lube. This is a fully synthetic lube that leaves a non sticky clear film on the chain. Protects the chain but doesn't attract dirt.
Old Jan 14, 2007 | 12:24 PM
Jason C's Avatar
Jason C
Plain old chain wax. I clean and adjust (when necassary) every 300 to 400 miles.
Old Jan 14, 2007 | 05:30 PM
i was using maxima chain wax forever, then i switched to motul chain wax. i'm liking the motul a lot better, but i'm still not 100% satisfied. even with a fairly light application i still get some black fling off... plus it's harder than he11 to get off the swing arm. i've yet to try the honda hp wax, but i hear it's great!
Old Jan 14, 2007 | 06:04 PM
Birdoprey's Avatar
try S100 cycle cleaner. it removes chain lube from anywhere, yet won't hurt paint, plastics or fragile wheels.
Old Jan 14, 2007 | 06:52 PM
Dave Wicks's Avatar
Scot-oiler
What is the Scot-oiler applying? What is in the chain wax??
I'm taking notes guys.. I ride alot in our short season..longevity matters to me
Appreciate the feed-back
Dave
Old Jan 14, 2007 | 07:48 PM
L8RGYZ's Avatar
I've used a variety of spray lubes on other bikes in the past.
I have nearly 28,000 miles on the original chain on my Super Hawk. I have always used 80-90 wt. gear oil to lube my chain & it still has plenty of adjustment left in it. Page 90 of the Honda Owner's Manual says, "lubricate only with SAE 80 or 90 gear oil."
All i do is put on a rubber surgical glove and wipe the chain down. I apply a light coat with a rag every few hundred miles. I keep the oil soaked rag handy in a dish in the garage. The main thing is to just lightly coat the chain to prevent rust & corrosion.
It's cheap & easy. And it doesn't attract dirt and grit the way many spray-on lubes do, so i don't have a messy build-up to clean off everything.
Of course other lubes will protect your chain, but this works for me.
Old Jan 14, 2007 | 07:53 PM
Dave Wicks's Avatar
Chain Lube
That's working well..likley the cheapest..might be a little tricky on a trip..but not impossible...carry bottle..throw away j-cloths..hhmm..
Thanks
Dave:-D
Old Jan 14, 2007 | 07:58 PM
dogman_010's Avatar
dogman_010 is on a distinguished road
I used to use Maxima chainwax but whe I pulled apart the chain to replace it I found the pins had rusted and the chainwax was doing nothing. I now use Bel-ray superclean (teflon based) which is a much better product.
Old Jan 14, 2007 | 08:01 PM
marmaladedad's Avatar
Hmm?
Dave
The Scottoiler is a lubing system (simplified, an upside down bottle) that puts a drop of oil onto your chain every so often.
http://www.scottoiler.com/
Old Jan 15, 2007 | 12:32 AM
After I used all my "Scottoil", I switched to a combination of Marvel Mystery oil and SAE30 cheap stuff, to approximate the consistency of the Scott oil. It's worked fine for many years and I have the thing adjusted to 1 drop/minute. I have to refill every 300 miles or so. Fling off is minimal and will occur mostly on the wheel and a few specks on the tail fairing. But it's so light that it wipes off with a rag. The system basically self-cleans the chain whenever you're riding. You can turn up the flow when in dusty or wet conditions, though I never do.
Old Jan 15, 2007 | 03:33 AM
keb57's Avatar
keb57
+1 on the gear oil. I use Mobil 1 synthetic and I apply it with a tooth brush with the bike on a stand and wipe off any excess. A bottle of gear oil lasts 3 to 4 years and my chains always go at least 25,000 miles. The fling wipes away with little effort and my chain always looks clean.
Old Jan 15, 2007 | 06:43 AM
altosuperhawk's Avatar
I used to use BelRay Super Clean for years. Went on light grey in color and absolutely would not fling off. About a year or so ago I tried a can of the new formula Honda HP4 with Teflon (could very well be a relabeled can of Dupont Teflon lube) and I'm very satisfied with it's performance. Goes on so clear that I've resorted to putting a mark on a sideplate so I don't overlubricate the chain while I spin the wheel and apply. Doesn't fling either. I clean the chain with kero every 350 miles, dry, and apply the lube. I'm over the 28,000 mile mark on the '98 VTR, over 31,000 miles on my '97 Bandit 1200,and 24,000 miles on my '99 ZRX1100- all on original chains and spockets. No holeshots or stunts may also contribute to the longevity....
Old Jan 15, 2007 | 04:03 PM
dogman_010's Avatar
Thats very good mileage from a chain. When I had my 02 VFR I only got 20,000Kms (only 12500mls) before some of the links had siezed and I replaced it. (and I ride like a nana)
That was using maxima chain wax applied after every ride.
I consider it next to useless.
I think I will try using gear oil as someone else said. You can get some very good light gear oils (SAE 75-80) designed for small manual transmission front wheel drive cars that may be the go, even maybe a synthetic.
The Bel Ray gets expensive after a while.
Old Jan 15, 2007 | 06:05 PM
Thumper's Avatar
+1 on the WD40, just like hawrider i have 25k on my original chain and sprocket and i have only used WD40.
Works great, keeps the chain clean and doesn't cause a damn mess on the swingarma nd wheel.
YOu do not need oil or wax on the chain rollers, that is why they have o-rings and grease inside the roller. The roller hits the sprocket teeth and then the center of the chain pivots while the roller stays stationary in the sprocket teeth, thus the reasonm for grease inside the rollers.
Old Jan 15, 2007 | 08:36 PM
Dave Wicks's Avatar
Chain Lube
What about belts...kidding..I'm learning from all your experience. The pins are lubed in modern chains...but the rollers as mentioned actually need lubrication for wear, heat and noise...sounds like proper lubing may also prevent moisture from entering rollers..may also lubricate the o-rings/x-rings etc..keep them from deteroiating..from rust,crud or heat.. Of course the pressure placed on them by hard riding also plays it's part...cleaner and lubricant most be compatible with o-rings..etc..small front sprockets will accelerate wear, by making the chain make a tighter angle..more movement..Of course dropping the clutch..etc.. Most of you all seem to be into your bikes so chains are looked after..the nightmare of packed up chains ruined a lot of engine cases and caused some tragic crashes... Nuff said..thanks guys for your input..
Dave:-D
Old Jan 16, 2007 | 07:13 AM
L8RGYZ's Avatar
Thanks
Dave:-D
So to sum up, there are several effective ways to lube your chain & get long wear w/o gumming it up.Since people have good results with it, think I'll get a small can of WD40 to carry on longer trips, where putting on the gear oil is impractical. Thanks for the tip.
Old Jan 16, 2007 | 04:19 PM
Dave Wicks's Avatar
Chain Lube
Hey guys..good input..WD 40..the wonder drug...I remember years ago in the days of air-cooling..it was Marvel Mystery Oil....Anyway..what I'm going to do is carry small can of WD 40..and then something for Lubricating maybe that Honda stuff..Anway thanks for all the "answers" to my question
Dave:-D
Old Mar 13, 2007 | 01:21 AM
GreyBeard's Avatar
GreyBeard
+1, again on WD-40, it's all i've even used on my chain; 25,000 miles and the chain and sprockets are still in very good shape. Sold my buddy on it too, it is all he ever uses. Cheap, works, doesn't gunk up the chain and attract dirt to grind your o-rings down.
Old Mar 13, 2007 | 05:32 AM
GrayHawk's Avatar
GrayHawk is on a distinguished road
On the Scottoiler, do you recommend the the Universal or High Temperature Kit for Mississippi? Ambient temperature range is from 68-122 degree Farenheit for the high temp version. Daily averages for that area are a low of 31 for January and 91 for July. I know temps can reach about 100 F on hot days during summer months.
Regards,
Mike
Old Mar 13, 2007 | 07:24 AM
GrayHawk's Avatar
p.s. Does anyone know of Scottoiler suppliers in the U.S.?
Old Mar 13, 2007 | 08:37 AM
bkelsey's Avatar
bkelsey
Aerostich has them.
http://www.aerostich.com/catalog/US/...r-p-16855.html
