Carb tools. mixture screw
Old May 17, 2010 | 09:24 AM
Jens_denmark's Avatar
Jens_denmark is on a distinguished road
Hi
How the f... can i adjust the mixture screw on the carbs, impossible to get in there. tryed a million times now. getting fustrated :-(
I bought one of the cheap tools on ebay, but it cant go in there either.
So how do you guyes do it ?
Jens.
Old May 17, 2010 | 09:34 AM
Well that depends on what mixture screw you have... On the older models before they started mucking with legal stuff the carbs had a normal philips head type screw... Mine being a 97 has that, so all I need is an angled screwdriver, easily available in most hardware stores... That and some patience... (lots of it actually)
If your bike is a bit never the screws have a "D" shaped head, so then you either need to remove the airbox and such to remove the carbs and slot them prferably using a dremel or such so you can use a normal slot or philips head bit afterwards...
Or if you don't like tearings stuff apart and have deep pockets, buy this http://www.motionpro.com/motorcycle/partno/08-0229/ which has the "D" shaped bits...
Old May 17, 2010 | 10:11 AM
I also have the /97 model
Old May 17, 2010 | 10:46 AM
residentg's Avatar
Tweety, will pilot screws from a '97 fit an '05? I would think so, but I thought that you might know for sure - thanks.
JB
Old May 17, 2010 | 10:48 AM
JB
AFAIK they are identical apart from the head of them so yes, they should fit nicely...
Old May 17, 2010 | 10:49 AM
And with you in Denmark I'd say then I'm 99% sure you have the philips head screws, so any 90 degree bit screwdriver should work fine with a bit of patience...
seb421
Jul 1, 2013 05:06 PM
Fox
Dec 14, 2010 11:46 AM
selztoad
Aug 26, 2006 08:05 PM
99Hawk
Sep 15, 2005 09:55 AM
99Hawk
Apr 30, 2005 06:01 PM
