Carb part question
2nd mouse gets the cheese
Carb part question
Is part 26 and 25 removable?
http://www.bikebandit.com/houseofmot...k-2000/o/m2914
also is it possible for this part wear out from the needle bouncing around. I thought I remembered a post taking about this but when I searched I couldn't find it. I have about 48k miles and I have been trying to dial it in and so far I have tried every needle setting, but it doesn't fix my stumble and slight miss at 3 to 4 k rpm just mildly changes the severity, so I am beginning to think its something worn out hence the question. Thanks everyone.
Yes they are removeable..but virtually impossible to wear out, all it priciply does is hold the main jet, however front and rear are different and they may have been inadvertantly been swithched. One has the metering holes toward the base the other toward the top. I don't remember which is which but I know there is a thread around here talking about it at Dyno Jet or Factory pro...In fact now that I think about it I believe it was factory pro's site.
Last edited by HRCA#1; Jul 2, 2009 at 07:57 AM. Reason: Corrected my response to conform to the question!
It has a dynojet installed about a yr ago, so new needles. I may try a deep clean, will seafoam take care of this or should I clean it by hand? I doubt the emulsion tubes have ever been accidentally switched. I am running aftermarket pipes and a bmc air filter. Before I switched to better flowing pipes and was running debaffled stockers I had the same exact issue. It just seems as though something other than jetting settings is causing my issue is all. Maybe something clogged, but the bike never has sat for more than 2 months. Runs like crazy up top and under accel, but at steady 3 to 4 k stumble city.
Seafoam?
(settings dynojet 180/185 needles 4th notch+washers pilot #48 screws 2 turns, but idle still too rich)
Seafoam?
Hand clean the tubes.
and if needles wear out, and it takes very little wear to make them bad, the electro-plating on the aluminum surface will wear thru. Should be quite visible when this outer layer is penetrated at all.
All it takes is a ****-hair of physical wear to make them go out of range.
Seafoam?
Seafoam?
Emulsion tubes DO wear and cause driveability conerns. Since the needle rests on the bottom of the tube, and rides there, it will cause the emulsion tubes to wear out of round. You will be able to notice an egg shape to the tubes. I have seen this happen quite a few times.
bpw
Nov 26, 2013 10:16 AM
