bt016 tire pressures?
Old May 30, 2010 | 06:14 AM
uchi's Avatar
ive been playing with the tire pressure on my bike and this year im riding alot more aggressively than i was last year and i started finding that the bike almost felt like it was loosing the *** end in really sharp corner, best way to describe it is that i was leaning and id lean it a bit harder and it felt like i rolled over a ledge of sorts. so i checked the pressure, cold it was 36 front and rear. i talked to some guys and they said thats fine for hiway touring but for the stuff were doing its too much. so i aired down to 32 cold and last night after my ride the rear after cooling for a few minutes was at 38 which seems high. my question is this, to the guys running the bt016s and doing alot of aggressive turning, even track days on these days, what are your cold tire pressures front and rear?
im asking here and not in a generic bike forum because its bike specific i feel, between the weight of the bike and its handling characteristics and the same tire id get a better answer here.
also whats the max id want to see the hot pressures get and still have a tire with lots of traction?
Old May 30, 2010 | 06:17 AM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
On the street, I run 36F, 42 Rear. Never had an issue anytime. We ride normal to really aggressive. On the track, 32F,30R. cold settings
Old May 30, 2010 | 08:54 AM
Red_Liner740's Avatar
that falling of the edge is what i experience on my front tire when i lean over hard, past the point of where it was leaned over before...so its a fresh tire thing. it feels like your bike just fell over for a split second.
i run 36 rear and 34 front and its worked fine for me. had the rear at 32 last weekend to try it out and it was balling up too much for a regular type riding.
Old May 30, 2010 | 12:14 PM
rackovanz's Avatar
rackovanz is on a distinguished road
I run BT016s and for track days I use 32f 30r, and she sticks like glue.
Old May 30, 2010 | 12:47 PM
dickard37's Avatar
dickard37 is on a distinguished road
+1 except I don't run at a track, thats what I run on the street though.
Old May 30, 2010 | 01:08 PM
RWhisen's Avatar
Former Superchicken Owner
Originally Posted by SPRHK
On the street, I run 36F, 42 Rear. Never had an issue anytime......
+1
Old May 30, 2010 | 04:07 PM
nath981's Avatar
i run 30f/28r cold now for the present Q2s and previously for the bto-16 and I minimize straight roads like they make me sick. I weigh about 175lbs with rt fork springs and JD modded rear shock.
Old May 30, 2010 | 04:33 PM
uchi's Avatar
excellent thats the info i was looking for thanks alot guys.
redliner thats the exact same feeling im talking about. the tires been over almost all the way the chicken strips are tiny 1/4 inch at best. but im guessing since i dont spend much time on the edge that far that its just some sort of a flat sport that im working in as you mentioned. good to hear.
i tried running 42 last year in my bt021st that came with the bike and i found the bike was coming out a little in some corners so i dropped to 36 cold and it felt better. im just about to head out again ill adjust the pressure one more time as its cooled off from this afternoon.
thanks again for the info
Wolverine
Apr 1, 2013 01:59 PM
speedkelly@aol.com
Jun 17, 2012 10:06 PM
oahu hawk
Aug 29, 2008 02:12 PM
AZZKIKER
Jun 7, 2006 01:48 AM
superchicken
Jun 8, 2005 11:22 AM
