BMC filter.....kind of...
Old Apr 3, 2012 | 01:52 AM
chemomche's Avatar
chemomche is on a distinguished road
Hi, when i bought my bike the seller told the it has BMC filter. A couple of days ago i opened the air box to do the TPS mod and i found this
I think it is a BMC filter from another bike that is fitted on the original filter plastic plate.
My question is - does BMC filter haw the plastic part that stops the air or i should cut it out(as some people do on a OEM filters)?
Plus, do i need some rejetting for the current set up - i got open cans and fuel pump....and as i know i don`t have jet kit installed.
I am thinkig of shimm mod + lond front air funney ....will this be enough fot the BMC filter and the cans?
I can`t put it on a Dyno so it will be hard to tune the carbs perfectly.
Old Apr 3, 2012 | 02:22 AM
Stephan's Avatar
No, BMC doesn´t have this plastic ridge. You don´t need dyno to tune the carbs perfectly, just feel how it goes.
Old Apr 3, 2012 | 03:19 AM
chemomche's Avatar
i see it is quite the same as mine, except the ridge
i do not haw much time to ride, so no time for thest rides and tuning also
if i go without the ridge(or as it is now) should i just go up with the mains/pilots or have to get a jet kit
Old Apr 3, 2012 | 03:33 AM
rz_racer_69's Avatar
Old and dangerous
Are you currently having a problem with you bike running? If not, I would say leave well enough alone unless you are trying to eek out a couple more HP. These bikes are known for being finiky with non-OEM filters, and the OEM filters flow more than enough air. Read the many threads on the site about that before you start hacking a working setup.
Old Apr 3, 2012 | 03:46 AM
Stevebis1's Avatar
Ha- that's not a BMC, that's an OEM modified with a Fram reusable filter. I'm not sure if I saw it on this forum or one of the others but at one point people were experimenting with cutting out the papefnelement on an poem and glueing in a Fram reusable element.
One key point was that the plastic dam could be left in place. Haven't seen this in a while think it was early 2000s this was being discussed
Old Apr 3, 2012 | 03:49 AM
chemomche's Avatar
i have no problems runining, may be just sametimes a flat spot at about 3k
however, i got the bike this way so i cannot tell if it run better ot less than the original set up
P.S. of cource i want some extra hp
Old Apr 3, 2012 | 03:57 AM
chemomche's Avatar
more likely to be BMC from onother model - you see the red plastic cutout around the filter, it is not just the filter element pun on the OEM plastic
Old Apr 3, 2012 | 04:03 AM
Old and dangerous
You might try an OEM filter then. There have been cases where going back to stock filter fixed all or mist of the running problems.
mortbike
Mar 13, 2016 06:38 AM
mikstr
Mar 1, 2009 12:35 PM
kostavtr
Oct 20, 2008 06:43 PM
Radiaoktiv
Jan 31, 2007 06:17 AM
Speed_Demon
Dec 26, 2006 11:16 AM
