Battery Lesson Learned
Old Jul 31, 2009 | 08:57 AM
Erik S.'s Avatar
If you don't check the screws on your battery, start doing so.
I went to start the bike, no go. Go to check Voltage, and guess what I find. The top of the negative post was slag. The screw was still in the keeper with wires attached. Apperently, the screw got loose and wiggled in the post, causing arching and overheating and melted the lead post.
$90 (after discount) later, a few moments time and some blue thread lock applied, the new battery is installed and the Hawk lives again.
I'm adding this to a list of things to check on a regualr basis.
Old Jul 31, 2009 | 09:40 AM
JamieDaugherty's Avatar
Hummm... that's interesting. With all of the bikes I've ever owned I've never had that happen. I agree, it's probably something to check when you have the seat off.
Old Jul 31, 2009 | 12:41 PM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
I've had the exact same thing happen. Lost 2 batteries that way. Shame there isn't a way to replace the posts!
Old Jul 31, 2009 | 04:58 PM
Erik S.'s Avatar
RPV, we've had a few ideas. The posts are lead. Possibly melting some fishing weights, let it hardened with a screw in it, then back the screw out. The hard part would be adding the melted weights to the battery without damaging the plastic. Hmm, would a soldering iron be hot enough?
Old Jul 31, 2009 | 05:14 PM
RPV-Hawk's Avatar
I "tried" to remelt the lead back into the shape using popsicle sticks as guides and a dowell for the bolt hole, but the "molten" lead doesnt' adhere to the "cold" lead left in the post. It moulds to the shape, but when the molten lead cools, it doesn't bond, it stays 2 seperate peices.
It appears to need "flux" like solder does to get it to stick. I tried using soldering flux but with no luck. Wouldn't stick/bond.
BTW Cheap radio shack soldering irons aren't hot enough, but I know pro-grade units have adjustable temps...they might be able to do it.
Tofazfou
Aug 3, 2014 10:19 AM
maniac2313
Jun 29, 2012 12:49 PM
finepooch
Jun 20, 2010 10:24 AM
inderocker
Jun 26, 2009 12:46 PM
midijunky
Sep 8, 2007 01:03 PM
