Back Brake Noise
Old Apr 22, 2010 | 06:05 AM
thusspakebenji's Avatar
thusspakebenji is on a distinguished road
Back Brake Noise
Slight squeak from the back brake when I'm paddle walking it, not all the time, only sometimes. The brake pads look new-ish, could this be the reason?
Old Apr 22, 2010 | 07:10 AM
Moehawk005's Avatar
98' SH stock
Moehawk005 is on a distinguished road
hey thus it sounds like there could b dirt on ur wheel or spoke
Old Apr 22, 2010 | 03:01 PM
nekkid's Avatar
Could the rear wheel be slightly out of alignment causing the rotor to not run parallel to the slot between the brake pads?
Old Apr 22, 2010 | 03:04 PM
residentg's Avatar
try spraying brake cleaner in the pad area, and wipe down the rotor - do it carefully, nasty stuff
Old Apr 22, 2010 | 04:16 PM
thetophatflash's Avatar
Make sure the caliper axle is not seized and the pad dragging more than normal.
Old Apr 22, 2010 | 05:39 PM
You mean it has back brakes?
Old Apr 22, 2010 | 06:41 PM
residentg's Avatar
Good point - the rear brake is a single piston floater, it needs to be able to move.
Old Apr 22, 2010 | 07:13 PM
It looks like the piston is pushed towards the rotor. When I depress the back brake I dont see the piston push in so I'm pretty sure I need new back brakes.
Old Apr 23, 2010 | 07:42 AM
peterpanic's Avatar
pragmatic anarchist
Take it off and clean it up. Mine was acting up. Wouldn't hold on a hill, then would grind a little, then get grabby. Cleaned up and new pads... GTS.
Old Apr 23, 2010 | 07:47 AM
peterpanic's Avatar
pragmatic anarchist
and in Back Brake Mountain I think they always made a noise.
Old May 4, 2010 | 08:32 AM
Took em apart, cleaned em, good to go, need to get some new pads though. The retainer pin was rusted so I used some Nev-R-Dull and polished back to a healthy sheen. No more noise, no more drag
thedeatons
Mar 26, 2015 04:36 PM
kenmoore
Oct 5, 2014 09:12 PM
Otto Man
Dec 13, 2006 10:35 PM
CNI Dawg
Nov 6, 2005 06:59 PM
tomgpdx
Jul 26, 2004 03:48 PM
