Alternator cover removal question
Old Jul 29, 2014 | 07:24 AM
jswisc's Avatar
jswisc is on a distinguished road
I'm replacing my cct's. Removed the inspection disc on the alternator cover with no issue. The center plug would not come out and is stripped. I know I can get it out but I know some advise just turning the rear wheel. I'm removing my valve covers anyway to check valves so the correct TDC is assured. OR, can I temprarily remove my alternator cover to turn the crank and when done reinstall?
Old Jul 29, 2014 | 07:51 AM
rick's Avatar
rick is on a distinguished road
Yes. But you will have to replace the alternator cove gasket.
Old Jul 29, 2014 | 08:22 AM
jswisc's Avatar
Any issues of using the rear wheel to turn the crank? Seems to be the easiest. Just not sure how easy it is to hit the tdc in just the right place, although w/ valve covers off maybe not so important.
Old Jul 29, 2014 | 09:04 AM
rick's Avatar
no problem using the rear wheel to turn the engine over. Put it in 6th gear to make it easy.
Old Jul 29, 2014 | 11:43 AM
jswisc's Avatar
Thanks.
Old Jul 29, 2014 | 06:16 PM
cybercarl's Avatar
Thumbs up
Centre cap on the generator cover removal. As it's made of cheese it's knackered so get a replacement otherwise you will have oil spray out with the engine running.
OK how to remove the mashed up cap. Heat the surrounding area with blowtorch, DIY (home depot) style butane or butane/propane mix gas burner will do the job. Then use a centre punch and a hammer and hit the cap a few mm in from the outside edge as there is a lip. Keep hitting it at a slight angle knocking it around in an anti-clockwise direction.
Old Jul 30, 2014 | 01:36 AM
Wicky's Avatar
Old Jul 30, 2014 | 04:55 AM
I bonded a 10mm hex bar into the plug that projects out about 8mm because my case guards blocked access. So now a standard 6-point box wrench removes the plug and a 1" long 1/2" or 3/8" square bar in a 6-point socket through the cover hole on the flywheel bolt also is turned with a 6-point box end wrench.
Old Jul 30, 2014 | 05:05 PM
comedo's Avatar
I removed the centre cap as cybercarl did except that I used boiling water from an electric kettle as a heat source. Loosening and tightening the cap every couple of months or so keeps it free.
Old Jul 30, 2014 | 05:47 PM
Both a open flame and boiling water seem like a recipe for disaster. I use a hot air (heat) gun on low (mostly)...
Heat Gun - Dual Temperature Heat Gun, 1500W
on sale often for $8
Big Shepp
May 12, 2012 02:23 AM
miner1098
Jul 15, 2010 03:54 PM
printdoctor
May 29, 2007 11:25 PM
johnnyhonda
Mar 24, 2007 01:39 PM
Mick-e
Nov 5, 2006 03:35 PM
