Afraid to ride in the dark...
Old Apr 1, 2015 | 06:34 AM
Booker909's Avatar
Booker909 is on a distinguished road
My brake light works fine but the tail light doesn't turn on when I start up the bike. I replaced the wiring harness to resolve some other issues hoping it would also fix the taillight but to no avail.
Can anyone tell me what I should be looking at to get this fixed?
Old Apr 1, 2015 | 06:51 AM
thedeatons's Avatar
Did you check the bulb?
James
Old Apr 1, 2015 | 09:29 AM
Booker909's Avatar
James
The bulbs work since they are the same bulbs the brakes use.
Old Apr 1, 2015 | 09:31 AM
996thehawk's Avatar
996thehawk is on a distinguished road
Its a dual filament bulb. Replace it and go from there.
Old Apr 1, 2015 | 11:12 AM
You should replace the bulbs, on filament can burn out leaving the other one.
Look on here for the wiring diagram to find what wire colors to test. There is a bundled of bullet connectors in the tail. Your tail lights are likely unplugged if the bulbs are fine.
Old Apr 1, 2015 | 01:50 PM
Big_Jim59's Avatar
We had a customer that rolled in on a Triumph. He said "look at this" and he pulled the brake lever and the headlight came on. He said "I know this is not possible. I looked at the schematic and they two circuits are separate." My boss told hin to go up front and buy a tail light bulb and that we would put it in for him. The trouble was, the tail light filament broke, since it is the lightest of the two filaments, and it fell down onto the brake light filament. When the brake switch was engaged the circuit sent power through the lighting circuit to the headlight.
Old Apr 1, 2015 | 03:39 PM
Jim that is a crazy story. I thought one in a million dilemas only happened to me!
Old Apr 1, 2015 | 04:26 PM
Thumbs up
Report back after you check suggested bulb. If you've never seen one they look like this:
If one of the two burn out, you will loose either bright brake lighting or the dim running light.
Old Apr 1, 2015 | 07:54 PM
Damn that's a big *** bulb!
Old Apr 2, 2015 | 04:39 AM
No, according to Wolverine, that's a suggested bulb.
Old Apr 2, 2015 | 06:01 AM
996thehawk's Avatar
lol
Old Apr 2, 2015 | 08:16 AM
Booker909's Avatar
Thank you for enlightening me! Didn't know about the dual filiment. I'll pull them and take a look.
Old Apr 2, 2015 | 11:15 AM
Lightbulb
You're pretty bright to have noticed that.
Old Apr 2, 2015 | 12:06 PM
I know. Blink, and you could miss it. This kind of attention to detail is the filament that runs through everything I do. It gives great illumination to...eh, I'm done. I'm getting burned out on this.
Old Apr 2, 2015 | 12:20 PM
Pidge's Avatar
What an illuminating thread!
Old Apr 2, 2015 | 01:25 PM
I already did illumination. Thanks for playing.
Old Apr 2, 2015 | 01:44 PM
Pidge's Avatar
Oh missed it, I must have been blinded by the light. It is an incandescent thread though!
Old Apr 2, 2015 | 02:05 PM
Touché. Nice usage.
Old Apr 2, 2015 | 04:26 PM
You guys are really bright.
Old Apr 2, 2015 | 04:47 PM
Old Apr 2, 2015 | 05:16 PM
Wow, Crux, that was funny six hours ago.
Old Apr 2, 2015 | 05:25 PM
Old Apr 2, 2015 | 05:26 PM
I'm aglow with happiness that this thread has went this far.
Old Apr 2, 2015 | 08:35 PM
Old May 21, 2015 | 07:32 PM
Booker909's Avatar
Figured I'd finally update this thread with what I ended up doing with the taillight. I bought one of those ebay led taillights. I just installed a new wiring harness and there was no way I was going to cut it up. I sawed off the piece the bulb goes into and wired it to the new taillight so I could just click it in. Also got some male thingys to wire the turn signals to. It's not as pretty as stock but it's exactly what I wanted to do.
Old May 21, 2015 | 07:45 PM
Good job, just hope you weren't riding around invisible all this time! I wouldn't have cut the harness either.
GlockPointer
Jan 5, 2012 07:19 AM
Erik S.
May 24, 2011 08:08 AM
8541Hawk
Mar 3, 2010 03:30 PM
finepooch
Aug 22, 2008 05:30 AM
vtrlvr
Feb 12, 2007 12:59 PM
