98 VTR only starts in neutral
Old Apr 25, 2008 | 03:58 PM
djkaoscc's Avatar
djkaoscc is on a distinguished road
Hey guys. I have a 1998 VTR 1000 and of late the bike will only start in neutral. If it cuts off I have to put the bike in neutral to start it. Any suggestions on what the problem may be?
Old Apr 25, 2008 | 04:14 PM
Blue Ridge Boy's Avatar
Just to get this question out of the way.....Are you holding in the clutch when you are trying to start it while in gear?
Old Apr 25, 2008 | 04:21 PM
Clutch switch bad or connection is loose.
Old Apr 25, 2008 | 04:22 PM
If your stand is down and you're in gear it won't turn over (due to interruptor on stand). If the stand is up and it still won't turn over, it could be that your clutch is dragging and/or your battery is weak.
Old Apr 25, 2008 | 05:01 PM
steener's Avatar
steener is on a distinguished road
+1 on the clutch switch. same thing happened to my '98.
Old Apr 26, 2008 | 05:16 AM
Hammer7205's Avatar
Hammer7205 is on a distinguished road
What about kickstand switch hanging up???
Old Apr 26, 2008 | 05:20 AM
FTMS's Avatar
Sounds like a saftey switch, clutch or side stand.
Old Apr 26, 2008 | 06:34 AM
BeerHunter's Avatar
Slacker
-1 ... If the side-stand switch was hanging up, then the bike would start in neutral and then as soon as the transmission is engaged the engine would die, thus making the bike unusable... +2 on the clutch switch
Old Apr 28, 2008 | 02:08 PM
Hammer7205's Avatar
Good point....
Old May 17, 2008 | 11:27 PM
haknslash's Avatar
Sorry to bring up an old thread but I was doing some searching because mine does this same thing. I was wondering if this was a normal thing the VTR did as I'm a new owner. I'll look into those possible problem areas mentioned above. It's not a big immediate issue to me, but I would like it resolved.
Old May 18, 2008 | 02:44 AM
FTMS's Avatar
If it is a bad saftey switch it is not just a SH problem, more like a common problem with that type of switch.
Old May 18, 2008 | 05:27 AM
lhoward1134's Avatar
lhoward1134 is on a distinguished road
Check your wiring going into the switch. I about replaced it, then I realized I'm an idiot and one of the wires came loose when I had the clip-ons off. Don't know how much Honda will want for that switch, but Granger or someone like that may have the same switch for a lot less. It would just take some digging. I guess this is probably a normally open switch.
Old May 18, 2008 | 10:34 AM
haknslash's Avatar
Just reporting back on mine, it turned out to be the clutch electrical connectors weren't ..... well... um.... connected . I figure they became disonnected in the process of strapping the bike down when I bought it from the previous owner. Simple fix and knew it had to be something like that LOL. As mentioned, check your wiring and connectors .
Old Jul 28, 2008 | 01:18 PM
StoneJrW's Avatar
StoneJrW is on a distinguished road
Hmmmm mine is only starting in neutral now also. I'll have to check said connection when I get home.
Old Aug 3, 2008 | 09:05 PM
BLAKCK HAWK's Avatar
BLAKCK HAWK
mine goes back and forwd, i just be happy when it strts that i dont check why ?
Old Aug 4, 2008 | 10:02 AM
Unclutchable's Avatar
Unclutchable is on a distinguished road
I think mine has been disabled. it starts in any gear, clutch in or not. brother tried to fire it up and he's not as bike savvy as I am, kinda scared him a little the time i had forgotten to put it in neutral when i parked.
Old Aug 27, 2008 | 10:05 AM
StoneJrW's Avatar
Forgot to post what I found on this. Everything was plugged in and I couldnt figure it out. After a few days I remembered that I changed the levers about the same time the problem started happening. I removed the aftermarket (found on EBAY) lever and compaired it to the stock one and sure enough it was slightly different. I put the stock one back on and it started in gear. I put the aftermarket back on and you guessed it, no start. There is very little difference but I found a fix. I had adjusted the lever closer to the bar because, well, thats how I like them. Just for the hell of it I adjusted the aftermarket lever out further and now it start in gear.
Hayai
Dec 11, 2011 05:23 PM
j_bud2007
Jun 25, 2009 12:51 AM
Chuey
Jun 4, 2007 09:07 PM
Chuey
Apr 1, 2007 07:38 AM
vitter
Mar 11, 2005 11:57 AM
