929/954 Triple
Old Oct 8, 2011 | 10:26 PM
bass4dude's Avatar
bass4dude is on a distinguished road
929/954 Triple
Could the 929 upper and lower triple be machined out to fit a larger fork?
1mm more on the radius would do the ticket for me, but I'm concerned about milling it out.
Would I just be better off finding/making a triple with the right size?
Ease of fitment with the stem is what I'm looking for right now.
Old Oct 8, 2011 | 11:39 PM
Absolutely.. BUt Cost vs buying one that works out of the box (ebay box that is).
Some machine shops would not touch the project, some will, but it won’t be super cheap.
Pretty sure I can fix the triple in a milling vice and bore out the hole using an adjustable boring bar in the lathe head. ..
Or, make a fixture to hold it to a rotary table, then mill out the hole.
But that’s still significant time to get it right... but no cost in tooling or service related.. So perhaps worth it if the buy in was good and you can do the work yourself or for near free (friend that is a machinist)
Old Oct 9, 2011 | 12:23 AM
mertechperformance's Avatar
MandownMertech
1mil removed is still safe, i would venture to say swapping stems would be "easier" and cheaper.
it's a very common practice on Ruckus scoots to run other bikes triples to use other (larger) brake setups.
and truth be told buying upper and lower 929/954 triples isn;t all that cheap in the first place especially seeing it'll need machine work after
Old Oct 9, 2011 | 01:13 AM
bass4dude's Avatar
Getting the work done isn't so much of a concern, my uncle owns a machine shop.
I'm just worried as the paired triples for the forks that I have a line on have a larger stem than the SH. And while I had contemplated grinding and pressing out the stem, I'm still wary of affixing the stem on the larger I.D stem hole of the triples.
Granted, this is all just numbers on paper for the time being, but a free pair of marchesini forged mag rims are kinda pushing this towards a winter project, but I ride year round so I can't afford to put the hawk down right now for any extended stay.
If there's any 52mm triples off hand that anyone can think of with the same size stem as the SH a shout would be awesome right now. If not I'll order a set of both triples and get to figuring!
Old Oct 9, 2011 | 08:20 AM
dehning's Avatar
dehning is on a distinguished road
I know this doesn't help much, but I stumbled on a list of bikes by fork size a while ago, bike with 52mm forks are:
ZX-7R
ZX-9R (94-97))
ZX-12R
Speed Triple(05+)
Old Oct 9, 2011 | 09:09 AM
MandownMertech
if zx9 and zx7 are 52 z1000 is also probably 52
Old Oct 10, 2011 | 11:20 AM
scooter72's Avatar
scooter72 is on a distinguished road
If your uncle owns a machine shop, just make a new stem that will press into your new triples and then machined down to the SH bearing dimensions. I had mine made up to use the 08 CBR1000 triples. I also needed a bushing made for the upper triple, but all and all I think it took my machinist buddy about 45 mins to make.
Old Oct 10, 2011 | 05:36 PM
bass4dude's Avatar
This is actually almost exactly what he said hahahahaha. When I described the problem to him he said to just turn down another stem.
Well! Back to headache time trying to get a triple with the right offset
Old Oct 16, 2011 | 11:50 AM
slo1's Avatar
slo1 is on a distinguished road
Honda rs250 (newer inverted 52mm) should be plug and play. Steering lock sucks (less than a Duc), but that can be fixed.
Old Oct 16, 2011 | 12:00 PM
MandownMertech
yeah, cause those are easy to find as well as cheap and plentiful.....
smokinjoe73
May 24, 2010 10:47 AM
Erik S.
Jan 15, 2009 08:47 AM
Tweety
Nov 23, 2007 07:16 PM
vtromey
Apr 5, 2007 04:09 PM
KC-10ENG
Mar 9, 2007 08:19 AM
