What this wire?
Old Jul 6, 2013 | 03:50 AM
Rebirth98's Avatar
Rebirth98 is on a distinguished road
What this wire?
Putting my paper weight back together last night I noticed there was one wire I couldn't find a connection for. It is on the bottom of the tank directly below the gas cap. Any ideas? I though maybe the fuel low light in the cluster but it didn't seem to be attached prior and that light worked before I lost a cct.
Old Jul 6, 2013 | 04:44 AM
Wicky's Avatar
Photo?
There's a fuel gauge connector from the tank that joins up with the main loom back from the tank nr the battery.
Old Jul 29, 2013 | 11:23 PM
GTS's Avatar
GTS
Seasoned tech
If it goes to the square plate with 4 nuts holding it to the tank, kind of below cap then it's the fuel level gauge. It generally runs under the foam padding stuck to the bottom of the tank and under the back mount into the cluster of connectors directly behind the tank and under the seat.
OKCSuperChicken
Feb 26, 2009 08:27 AM
flyingeyepro
Feb 6, 2009 04:00 PM
redman
Dec 31, 2007 01:37 PM
snowman666
Apr 17, 2007 06:58 AM
