Track Day suspension setup
Old Jan 15, 2015 | 12:23 AM
NZSpokes's Avatar
How about a thread on everybodys track day set up?
Im 220lbs Naked
Forks, RT G2 Gold valves with C34 shim build, All ***** seals, .95 Racetech springs, Fork brace. I did raise the oil level but cant find my notes on that. No mods to rebound and currently set all the way on. -3mm on the crowns.
Shock is Ohlins, 1000lb spring, 8 clicks out on rebound and 10 clicks comp. +4mm lift.
Pretty happy with it but do feel some mid turn wallow or movement. I got a tip from an expert rider on a Hawk at my last track day to get my body weight further over the front wheel. This helped stabilize the bike and for the first time my front tyre has started to look worked at a track day.
Im open to any tips to.
Whats your setup?
Old Jan 15, 2015 | 09:50 AM
You know you coulda said "with no gear". Geesh, I was just about to have lunch! Thanks a lot.
Make sure you are NOT on the seat. Its tiring but will totally change the midcorner stability. Climb forward so your face is way up where the mirror would be.
You can also add stiffer/ more foam to the seat to get you up over the front wheel. I went way faster after adding some still foam over the stock stuff under the cover.
Tank grips work wonders to prevent overworking your arms and overloading the bars midcorner to upset the chassis.
Adding rebound should help the wallowing as should a bit of preload.
Old Jan 15, 2015 | 11:09 AM
NZSpokes's Avatar
Thanks Man
Guess what I was told was correct then. Im trying to do a deal on some rearsets which I think will help as well. I do have a taller touring seat which I had on the bike for the last day but it made me feel like I was on the bike not in it as it were.
Old Jan 15, 2015 | 11:38 AM
Oh yeah, as for the no gear thing. You should set static sag numbers with you and your gear. It makes a difference. You should start at 30mm each end between topped out and sag with you & gear (you need some guys to hold you & the bike up).
Old Jan 16, 2015 | 01:04 AM
NZSpokes's Avatar
Checked my modded seat over the stocker and the modded one is 40mm taller and flat.
Also did the cheap rearset job until I get my proper rearsets.
Old Jan 16, 2015 | 07:20 AM
Here is another strange thing that can help. Assuming you have stomp grips on the tank, armor all you seat & leathers. Be careful not to fall off, but doing this makes moving side to side off the bike way easier.
This seems like dumb stuff but proper body positioning is a huge part of active suspension on the bike.
You should also lower the front end by raising the forks to tune in quicker turn in and hold a line midcorner. (can sorta be done with rear ride height too to some extent)
Old Jan 16, 2015 | 05:22 PM
NZSpokes's Avatar
I will give the Armor all a go.
Jamie the suspension guy said on another thread not to lower the front. Which is something I had done so have lifted it up again. He gave me some specs for a mod to my rebound which I will give a go.
pearsonm
Sep 30, 2012 03:02 PM
RuthlessButcher
Apr 17, 2009 02:21 AM
Red_Liner740
Apr 2, 2009 08:52 AM
scarface
Sep 13, 2008 09:22 AM
scorpius
May 10, 2007 07:48 AM
