Thumb fuel screw query
Old Jul 18, 2015 | 09:43 AM
Can someone (smarter than me) point me to the post on replacing and adjusting the thumb fuel screws?
Been searching but cant find commentary on it.
Old Jul 18, 2015 | 12:21 PM
killer5280's Avatar
Take out old mixture screws.
Put in thumb screws.
Old Jul 18, 2015 | 01:24 PM
NZSpokes's Avatar
Well yes thats it in a nutshell.
Old Jul 18, 2015 | 04:53 PM
Haha, yeah no I mean the adjustment while its running (I think).
I think its all the way in then 2 turns out? Idling or at rest?
Old Jul 18, 2015 | 05:16 PM
scottiemann's Avatar
Adjusting the fuel screws is a part of the FULL process of syncing your carbs prior to actually syncing the linkage. If your carb settings are spot on or very good just match the turns out to what you have already, then follow the manual for fine tuning the screws and syncing the carbs.
Old Jul 18, 2015 | 05:36 PM
Jack Flash's Avatar
Well take off, eh.
Smoke, I think what you may be looking for is in the owners manual. If you go to section 5-18, you will find a clear explanation of how to proceed to adjust your carbs.
I honestly have failed to go through these steps since I'm too lazy to take the time, but, I think it's probably the smartest way to do it.
Old Jul 18, 2015 | 09:43 PM
Hmm. I will do that but the confusing part is that the fuel screws are not adjustable from the factory so why would Honda tell you how to adjust them?
Am I missing something? The carbs are synced so I was figuring someone had the screw turns figured out. Am I wrong about the screws from the factory? I had to slot mine with a dremmel to turn them. (or do they want you to use that dumb D shaped tool?)
Old Jul 19, 2015 | 12:10 AM
NZSpokes's Avatar
Because other countrys that are not in or about the USA got normal screws.
Jack Flash
Mar 30, 2025 10:12 AM
mikenap
Dec 19, 2014 10:36 AM
Jack Flash
Oct 20, 2013 05:51 PM
seb421
Jul 1, 2013 05:06 PM
Fox
Dec 14, 2010 11:46 AM
