Sprocket Swap
Old Sep 2, 2004 | 11:55 AM
pickle.of.doom's Avatar
pickle.of.doom
Sprocket Swap
Any preference on whether to go down 1 in the front or up a few in the back to bring to the power down into the usable range more? Is the front harder to change than the rear?
Old Sep 2, 2004 | 06:35 PM
Random's Avatar
Random
Re: Sprocket Swap
The 'standard' is one down in front, and 2 up in rear. This should net about a 10% change in effective gearing. You can go down MORE than 1 in front, or add more than 2 in the back, but rather soon, you'll find your fuel economy severely limited.
Changing the sprockets messes with the speedo, so be warned before you start.
Old Sep 8, 2004 | 01:39 PM
cdyer77's Avatar
cdyer77
I find it easier to change out the rear as opposed to the front. I have several different combo's that I use depending on either the track I'm at or what exactly I'm lookin for in street riding.
Old Sep 8, 2004 | 10:42 PM
pickle.of.doom
What would you recommend for a good city/backroad combination, that would also encourage accidental power wheelies on occasion?
Old Sep 9, 2004 | 12:43 PM
cdyer77's Avatar
cdyer77
Probably stick with the stock front and bump up to 43 tooth rear. Wheelies made simple! Also your fuel mileage goes down. You will also be running higher in the rev range.
Old Sep 9, 2004 | 03:44 PM
faz's Avatar
faz
faz
I can't wait to modify the sprocket on mine. My bike has about 9k miles on it and it is sort of at a place where if I want to change a sprocket, I should really change the whole thing, and I don't want to do that.
I am waiting until I hit about 15-16k before I change everything. (is that too high, btw?)
I think going up a couple of teeth on the rear should be a good modification from stock. as it is now, the bike is falling sleep at highway speeds, so I am thinking why not use the extra torque at the bottom end.
Old Sep 9, 2004 | 06:45 PM
cdyer77's Avatar
cdyer77
Ideally, you should change out the front & rear sprocket along with the chain at the same time. They all tend to "wear" the same and at the same rate. If it looks like the rear needs to be replaced, the front probably does as well.
Once the teeth start to get pointy...its time.
Old Sep 9, 2004 | 07:04 PM
pickle.of.doom
Re: Sprocket Swap
What about if your other sprocket and chain are relatively new? Like around 5k on em?
Old Sep 10, 2004 | 06:22 PM
cdyer77's Avatar
cdyer77
5K you should be ok with just a sprocket swap
Old Sep 11, 2004 | 12:00 PM
pickle.of.doom
Re: Sprocket Swap
Thanks for the info. I understand the fuel mileage and speedometer inaccuracy, and I can accept those I just find it unneccessary to have all that top end speed, when I rarely even get to break the ton around here. I want to bring some of that power down into my usable range.
duran
Aug 27, 2007 07:57 AM
Scumbag
May 6, 2007 10:46 AM
itsjason13
May 2, 2007 09:31 PM
willie
May 1, 2007 01:52 PM
steener
Apr 28, 2007 03:47 PM
