Shifter Mod
Old 09-27-2008, 09:26 AM
Woodytick's Avatar
Woodytick is on a distinguished road
Shifter Mod
has anyone tried flipping their shift over to change the gear pattern on their bike. i have my shift linkage flipped over on my cbr to make my gears 1 up and 5 down. was just wondering if i can do the same with this bike.
Woodytick is offline
Old 09-27-2008, 10:42 AM
pigwings's Avatar
pigwings
try searching
pigwings is offline
Old 09-27-2008, 06:52 PM
ole dirty bastard
hawxter996's Avatar
yes
hawxter996 is offline
Old 09-27-2008, 08:33 PM
Woodytick's Avatar
yes
thanks man, i'll flip it like on the cbr and go from there. did you do this to your bike. i personally like it better this way.
Old 09-28-2008, 04:46 PM
shayne's Avatar
If ou like a race pattern, and intend to stay with the set up, do yourself a favour and remove the linkages and just fit a new shifter straight off the spline.
I found the OEM joints in the linkages to have a lot of play in them, and the shift was imrpoved greatly by fitting heim joints in their place. I put up a article on hear a couple of years ago on how to do it. Makes a nice difference.
In your case if you fit a new shifter, you can get an even better result, as you will have a direct force on the spline without any linkages.
shayne is offline
Old 11-02-2008, 10:09 PM
Truckinduc's Avatar
I agree totally with shayne. I made some rearsets for my ducati and ran a shifter directly off the splines. No play what so ever and I love the shift pattern.
Truckinduc is offline
Old 11-03-2008, 06:43 AM
comedo's Avatar
I took up Jim TT's suggestion about fitting a shift lever from a 94 VFR750. It works fine if you've got small feet and it's got novelty value. My write up which understandably failed to elicit any comment can be found by searching this site for VFR750.
comedo is offline
Old 11-03-2008, 12:56 PM
ih8tu's Avatar
ih8tu is on a distinguished road
flipping it over works fine.
ih8tu is offline
09-25-2011 12:06 PM
Shawn Torpey
02-22-2007 03:46 AM
ejizzle
11-01-2006 06:14 PM
MXC
06-14-2006 04:14 PM
DaxMiddler
04-29-2006 03:25 PM
Quick Reply: Shifter Mod
