Shifter Mod
Old Sep 27, 2008 | 09:26 AM
Woodytick's Avatar
Woodytick is on a distinguished road
Shifter Mod
has anyone tried flipping their shift over to change the gear pattern on their bike. i have my shift linkage flipped over on my cbr to make my gears 1 up and 5 down. was just wondering if i can do the same with this bike.
Old Sep 27, 2008 | 10:42 AM
pigwings's Avatar
pigwings
try searching
Old Sep 27, 2008 | 06:52 PM
hawxter996's Avatar
ole dirty bastard
yes
Old Sep 27, 2008 | 08:33 PM
Woodytick's Avatar
yes
thanks man, i'll flip it like on the cbr and go from there. did you do this to your bike. i personally like it better this way.
Old Sep 28, 2008 | 04:46 PM
shayne's Avatar
If ou like a race pattern, and intend to stay with the set up, do yourself a favour and remove the linkages and just fit a new shifter straight off the spline.
I found the OEM joints in the linkages to have a lot of play in them, and the shift was imrpoved greatly by fitting heim joints in their place. I put up a article on hear a couple of years ago on how to do it. Makes a nice difference.
In your case if you fit a new shifter, you can get an even better result, as you will have a direct force on the spline without any linkages.
Old Nov 2, 2008 | 10:09 PM
Truckinduc's Avatar
I agree totally with shayne. I made some rearsets for my ducati and ran a shifter directly off the splines. No play what so ever and I love the shift pattern.
Old Nov 3, 2008 | 06:43 AM
comedo's Avatar
I took up Jim TT's suggestion about fitting a shift lever from a 94 VFR750. It works fine if you've got small feet and it's got novelty value. My write up which understandably failed to elicit any comment can be found by searching this site for VFR750.
Old Nov 3, 2008 | 12:56 PM
ih8tu's Avatar
ih8tu is on a distinguished road
flipping it over works fine.
Sep 25, 2011 12:06 PM
Shawn Torpey
Feb 22, 2007 03:46 AM
ejizzle
Nov 1, 2006 06:14 PM
MXC
Jun 14, 2006 04:14 PM
DaxMiddler
Apr 29, 2006 03:25 PM
