replacing valve stems
Old Sep 5, 2011 | 04:47 PM
20_rc51_00's Avatar
With the tire swap coming up I am also going to replace the valve stems. I was intending to replace them with some thing more permanent and reliable... ie not the OE rubber ones. Any recommendations? specific size? Alum vs steel? Those that tighten from the inside vs outside?
Thanks
Old Sep 5, 2011 | 08:56 PM
What's wrong with rubber valve stems? I've had new aluminum valve stems leak... but I've never had that happen with a new rubber valve stem
Old Sep 5, 2011 | 10:01 PM
msethhunter's Avatar
The ones that get tightened in are now where near as reliable as a good old fashioned rubber one. They tend to losen up and leak at the worst possible time, like on a long ride in the middle of nowhere. Stick with whats known to work.
Old Sep 6, 2011 | 06:28 AM
cliby's Avatar
I have had similar experience. I would use the shortest rubber stem that allows good access for air. And replace them at each tire change. The longer, heavier (metal), or right angled ones, for me at least have not been a positive. I don't know if its the heavier weight and all the forces on the stem over time that promote flexing and loosening, but it seems to happen.
Old Sep 6, 2011 | 06:36 AM
I installed some of the snazzy angled aluminum Ariete ones from Kurvey Girl....
nnjhawk02
Apr 29, 2013 07:33 AM
7moore7
Nov 11, 2010 03:47 PM
jkrswld
Feb 26, 2009 02:03 PM
mikstr
May 3, 2007 05:38 PM
Otto Man
Jan 6, 2007 01:36 PM
