Rear shock shim (spacer) what thickness should I make it ???
Old Nov 12, 2005 | 05:26 PM
CNI Dawg's Avatar
One of my buddies can make me a rear shock spacer.
I got the plan here:
http://webpages.charter.net/gnemish/vtr_shim.JPG
My questions are:
I'll get him to make the 5mm thick shim like the plans call for.
Should I get him to make others too ?
What additional thicknesses should be made?
7.5mm, 10.0mm, 12.5mm, 15mm etc?
OR 5mm then 10mm, then 15mm ?
I'm just not sure how much difference there is for the thickness of the shim.
Any info would be appreciated.
Old Nov 12, 2005 | 07:34 PM
caffeineracer's Avatar
caffeineracer
you'll be limited by the shock linkage contacting the exhaust cross-over pipe and full extension.
I believe it's 7-8mm of shim then it hits the pipe.
I think you run out of bolt threads as well.
6mm is popular shim that gives you about 20mm increase in rear ride height if I recall.
~Jeffers
Old Nov 13, 2005 | 05:47 PM
CNI Dawg's Avatar
Re: Rear shock shim (spacer) what thickness should I make it
Good info!
Thanks, Bill
Unzie57
Feb 3, 2013 05:58 PM
E.Marquez
Sep 24, 2012 05:12 PM
Storm
Jul 2, 2010 11:45 AM
superdave
Oct 27, 2006 04:39 AM
ClevelandSuperhawkRumble
Mar 25, 2005 01:27 PM
