Rc51 front end swap prep
Old Dec 20, 2013 | 09:56 AM
jscobey's Avatar
Just bought a full stock RC51 SP1 front end. Thanks yoomit. Wheel, rotors, calipers, forks, bearings, upper and lower triples, and clip ons. While I'm waiting for it to come, is there anything I should get in preparation? Brake lines, new bearings, etc? Just so I'm able to have everything ready for the swap once it's here. Ive never done a swap before so I'm not sure exactly what will transfer over and what needs to be replaced. Also any advice on prepping for the swap and or tips for while I'm doing the swap will be appreciated. I'm sure I'll come up with more questions once the parts are here. Thanks guys!
Old Dec 20, 2013 | 10:32 AM
Letsrideinsc's Avatar
Letsrideinsc
Good luck with your install. Sweet front end buy. Now Search.
Old Dec 20, 2013 | 02:24 PM
jscobey's Avatar
I search on here like a mad man. Making sure I don't overlook anything. I think I've got pretty much everything. The only think I'm not sure of is bake lines. Do I need new ones to use the RC calipers? I run a nissin master cylinder and 900rr calipers. Will any aftermarket VTR brake lines work? Or better yet will my current lines work?
Old Dec 20, 2013 | 02:30 PM
slo1's Avatar
slo1 is on a distinguished road
Originally Posted by jscobey
The only think I'm not sure of is bake lines. Or better yet will my current lines work?
should be fine. Measure from the top triple (new bottom should be gull wing) to the axle center before and after. Make it the same and all should be good with brake line length..
Old Dec 20, 2013 | 04:18 PM
jscobey's Avatar
Okay thanks. I'll reuse my current lines
Old Dec 21, 2013 | 06:29 AM
yoomit's Avatar
yoomit is on a distinguished road
slo1 ur here to??! ha!
Im not familiar with superhawks but i did notice the stock bars sit in top of the top triple.
The bars on the RC sit below its top triple.
Since ur transferring over all ur current cables, lines, etc the only foreseeable issue may be you'll have a bit more slack on all those items.
Not a huge deal, u can probably reign the slack in.
Old Dec 21, 2013 | 07:23 AM
jscobey's Avatar
That would be true but my whole front end was already swapped by the previous owner with a cbr900rr front end and the clip on are below the triple. I'm thinking there about the same place now as the new controls will sit after the swap.
Old Dec 21, 2013 | 07:37 AM
yoomit's Avatar
Hell then you'll be good to go!
My RR forks r due to arrive Tue.
I'll try to ship out the first 2 boxes before then.
Old Dec 21, 2013 | 08:03 AM
jscobey's Avatar
Sounds good. I'm trying to get all my ducks in a row so when everything arrives i won't run into any issues. One question, do the clip ons have any rise in them at all? From the pictures it looks like there's no rise at all on them.
Old Dec 21, 2013 | 08:49 AM
yoomit's Avatar
I think they have slight rise, but top of bars still end up lower than top of top triple.
I dont think the RC was designed for comfort riding ;p
thedeatons
Nov 27, 2013 11:30 PM
FL02SupaHawk996
Apr 18, 2012 09:41 PM
inderocker
Feb 9, 2012 07:44 PM
FL02SupaHawk996
Apr 17, 2008 08:54 AM
Kendrick
Oct 16, 2006 07:38 PM
