Race Tech Fork Rebuild
Old Aug 23, 2007 | 07:51 PM
reaper's Avatar
I have on order the Race Tech Gold Valve kit and 1.0 kg springs and I am 260 pounds. What else should I replace on the forks while I have it disassembled?
Also, what type and or weight of fork oil should I be considering with the new setup?
Thanks.
Old Aug 23, 2007 | 08:48 PM
With a 1.0 spring you will either need the rebound gold valve kit or you will have to revalve the stock rebound stack.
Old Aug 23, 2007 | 09:00 PM
nineighthawk's Avatar
nineighthawk
Racetech has some great oil.
I can't remember the weight I used. I just used what the tech at recetech told me. It worked perfect.
Old Aug 23, 2007 | 09:24 PM
reaper's Avatar
Hawk:
I am a little confused now.
Do I need the Rebound Gold Kit instead of the Gold Valve kit? Or will I need both to properly set-up the front forks?
What does it entail to revalve the stock rebound stack?
A lot of questions.
Thanks.
Old Aug 23, 2007 | 09:29 PM
There are two Gold Valve kits. One for compression, one for rebound. Since you'll have the fork cartridge pretty much down to parade rest anyway it takes another 10 minutes to do rebound. The rebound is the one attached to the rod. The compression is the base valve, bolted to the aluminum slug at the bottom.
If there's any chance you can cancel the Gold Valve order I can revalve your forks for you with better results than Racetech stuff. PM if interested.
Old Aug 23, 2007 | 09:40 PM
reaper's Avatar
I pm'd you.
ff
Nov 7, 2008 12:43 PM
HawkRider98
Sep 8, 2008 09:27 AM
FL02SupaHawk996
Dec 21, 2007 04:49 AM
CNI Dawg
Feb 26, 2007 05:09 AM
102dals
Nov 27, 2006 02:46 PM
